2000/2002 Emissions help
The engine he bought the next day was "from that 2000 Expedition over there". Once I got roped into helping get the engine out, I started noticing the differences in the engines.
Figuring the engine had to come out anyway, I took it out and started comparing them. The engine that was purchased was, I'm guessing by the belt setup and the wire harness, out of a 2002-3 Lincoln Navigator and found a sticker on the engine that backed up my suspicions saying it was made in '02. I figured both blocks were at least the same and I can try to make it work.
I now have the engine in and I had it fire up, making sure Dad wasn't duped there either.
I am at the point of putting the emissions system together and I'm at a mental block. I have vacuum ports with no hoses and hoses with no ports. lol I have looked on the '99 we have to be able to get most of it back on and I'm out of options. I have most of the parts from both engines and I can't route some of them anymore because I don't have the hose for it.
I wanted to see if anyone on here has any idea on what could be different and might be able to point me in a direction to get this truck going again.
Thanks in adavance for any help here. Apologies for the long post.
Are you saying you are trying to use the 2 valve head on the Navi block?
Which intake manifold are you using? I believe the Xpy used an IMRC where the Navi had a tuner valve inside the intake manifold.
I guess I am not sure just what you have. maybe a picture of what port you need connected would help someone back track to where the vacuum source would be on an Xpy vs a Navi.
I am using the block, heads, and intake from the 2002 motor. I believe the plenum, the back of the throttle body, I have on it is the one that was on the 2000. When I looked at the '99 for the routing of hoses, that is where my confusion began. There are extra ports on the '99's plenum that are not present on the one on the truck on which I'm working. For instance, on the one I have, it is missing a larger port on the left (driver's side) of the plenum and on the right (passenger side) the main port coming out is just one solid port vs the one I'm using for reference had the 3 way splitter on it.
I apologize for the lack of detail so far on my part, when the truck started to come apart, it was organized and then people decided to "help" me and ended up mixing all the parts together and some weren't even removed by me. This project has been a nightmare from the start. This has been the worst engine swap I have ever had to do (and didn't want to even do it in the first place...lol). I don't do any major work this uninformed. Unfortunately for me, I am trying to make all the mistakes everyone else made work, even though I feel like banging my head against a wall the whole way.
