Sponsored by: Real Truck
A/C Compressor squeal
Old Nov 9, 2017 | 12:03 PM
david772's Avatar
david772
Thanks for the clarification!
Old Nov 9, 2017 | 04:30 PM
david772's Avatar
david772
Well... While removing the bolt that holds on the clutch, the head of the bolt broke off. About 1/2" of the threaded part is sticking out of the shaft, but using a vice grips to try to get the bolt out just spins the shaft. Will probably need to have the whole compressor replaced. I'm inexperienced in what to look for as far as a worn clutch. The pulley bearing seems good. I've done nearly all my own repairs for 35 years, but I've reached an age that this job of replacing the compressor looks really cramped and too physically demanding for me. Thanks to those that offered suggestions!!!
Old Nov 16, 2017 | 05:18 PM
david772's Avatar
david772
Fixed! I was able to get the broken A/C clutch bolt out (long story). I noticed that the rubber had failed between the inner and outer pieces of the clutch. Thus, the high pitch squeal was made when the clutch engaged, and the two pieces of the clutch were not moving in unison, and the rubber in between squealed.
Old Nov 16, 2017 | 06:11 PM
TomTommy's Avatar
TomTommy
Excellent! Great news...just a clutch kit instead of a new compressor!
Herb Brooks
6.4L Power Stroke Diesel
Sep 8, 2015 12:01 PM
FORD X FORD
Jul 15, 2011 09:43 PM
Civilian
Jan 10, 2011 05:09 PM
PeterBrazier
1997 - 2003 F150
May 27, 2010 09:38 AM
BHE
Mar 16, 2007 02:25 AM
