Very Loud Siren Noise Turbo with Video
If you checked the codes again, you'd probably see new one(s) for the turbo.
P1247 - Turbocharger Boost Pressure Low
P0299 - Turbocharger/Supercharger "A" Underboost Condition
I would pull the intake boot to the turbo and give it a look. On my 7.3 I had a chunk of aluminum fly out of the inducer, made a terrible sound similar to what you are experiencing. If it is toast, which sounds like it is, you should see either damage on the wheel or when you grab the wheel to rock it will contact the housing. This is with engine off btw...
https://barderturboservice.com/produ...conversion-kit
https://www.dieselpowerproducts.com/...werstroke.aspx
For FYI:
https://blog.dieselpowerproducts.com...d-powerstroke/
Hope this helps...
#28
I purchased a 2018 F350 Crew long box and have encountered the same issue you describe, Took my truck in for a checkup and explained what I was hearing and was told that they could not reproduce the symptom therefore nothing was wrong with the motor. Today I am just over 10K miles and I hear the noise pretty much all the time. I haven't gotten underneath the motor to listen as at times I think its coming from the exhaust while driving.
I will see about video taping the noise while the truck is idling and listen to hear the noise as well as look over the boot, clamps and hoses and such and I will go back into the dealership and have them listen to it if present. What really frustrates me is that they tell me they have never heard of my problem before but supposedly have the best diesel mechanic in the district and yet here I am on this forum hearing of folks who are having the same problems as I do. Go figure!
