64 front end swap
Old Nov 4, 2017 | 04:02 PM
Exiled Saint's Avatar
Exiled Saint
64 front end swap
Hey everybody. I am new to this forum and pretty new to working on this type of truck. I have a 1964 F100 Flare side and have seen a lot about the Crown Vic front end swap. I have a couple questions and I hope you all can help. 1. Do the 03-09 cv's have the same bolt pattern? In not does any year have same bolt pattern? I don't want to change out rear end if I don't have to and i dont want 2 different wheels. 2. Will 15 in wheels work with the cv set Up? I am planning on bagging the truck and want to do it right. Thanks for any help with this..im a newb but I'm excited to get started.
Old Nov 4, 2017 | 04:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1) Do the 03-09 cv's have the same bolt pattern? If not, does any year have same bolt pattern?
Not the same bolt pattern as your truck.
I don't want to change out rear end if I don't have to and I don't want 2 different wheels.
2) Will 15 in wheels work with the cv set Up? I am planning on bagging the truck and want to do it right. Thanks for any help with this..im a newb but I'm excited to get started.
'03/2010 Grand Marquis and '03/2011 Crown Vic's have metric wheels.
Your F100 has 5 lug wheels on a 5.50" bolt circle pattern.
The older (1979/90ish Crown Vic's & Grand Marquis) have 5 lug wheels on a 4.50" bolt circle.
Excepting 1940/48's, there's no car of any year that has the F100's 5.50" bolt circle pattern.
Old Nov 4, 2017 | 08:27 PM
hello113's Avatar
hello113
you can take your axels out of your rear end and send them off to get re-drilled to the crown vic pattern and have the same bolt pattern all the way around
good luck
Old Nov 5, 2017 | 10:17 AM
Exiled Saint
Thanks for the info guys. If I do the front end swap can I keep the original rear end/axles or do I have to change that out as well?
Old Nov 5, 2017 | 06:08 PM
hello113's Avatar
hello113
you can keep the rear end just have to deal with the 2 different bolt patterns
or you can get a pair of wheel adapters that will also work
Old Nov 6, 2017 | 07:19 PM
jacobn936's Avatar
jacobn936
The 15" wheels will not fit over the CV front calipers. Need a minimum of 16" wheel.
Old Nov 7, 2017 | 01:13 PM
zackcj7's Avatar
zackcj7
Car, probably not. But Jeep also used that wheel pattern on the CJ series which lasted until 1986. I believe the Dodge D series pickups also used it for a while.
Old Nov 7, 2017 | 01:16 PM
zackcj7's Avatar
zackcj7
OP, have you looked into the Dakota IFS swap kits from Industrial Chassis? The upfront cost is a good deal more than the CV, but the track width and bolt pattern problems are taken care of.
mgargiullo
13
Jul 3, 2015 11:58 PM
phatkat
Jun 16, 2010 10:23 PM
1970460
May 15, 2009 08:05 AM
medicpg
Mar 31, 2008 12:52 PM
61Unibody400
Jun 16, 2006 04:15 PM
