Rv washing machine
Old Nov 8, 2017 | 04:07 PM
Krazyhorse's Avatar
Krazyhorse
Originally Posted by Phil Pasternak
Splendide is the brand most folks get.. I believe the combo you would be looking at would be a model 2100. The vented version works best.
Great machine. Had one in the Carriage, and new in the Bighorn.
Old Nov 8, 2017 | 06:27 PM
whooboy's Avatar
whooboy
Have had two Splindide Ariston washers. Threw the first one away after the control board went bad. The second one just threw a code that said the eeprom is incompatible. Really? Called the company and they said that the control board is bad. Another boat anchor. Looking for a new washer--anything but Splendide. Anything.
Old Nov 8, 2017 | 06:47 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Originally Posted by djousma
Dave,
I tried to google your make model trailer. i found a few floorplans that seem to show the w/d prep in the front in the bedroom? If so, is your space floor to ceiling? It looked similar to mine, and that without the w/d actually installed, it has a clothes rod across the top for hanging clothes and is just another section of the closet. In my cardinal with the w/d installed, they remove the rack, and install bracing across the top for the dryer. both appliances are smaller than normal home ones, and fit the space perfectly. they actually have brackets that attach the washer and dryer to make them one unit so to speak. Washer on the bottom, dryer stacked on top.
I'm sure you fully understand, I just didnt want you to artifically limit your choices if there was a clothes rod across the top where the dryer would be.
Thanks for taking the time. No ours isn't floor to ceiling. And yes I plan on taking out the rod. If I took out the panel above the rod then it would be a short floor to,ceiling closet. Will take picture of it tomorrow
Old Nov 8, 2017 | 07:53 PM
Iceman1777's Avatar
Iceman1777
We have the Splendide Ariston ARWXF129W washer and TVM63X dryer. Full timing two years, zero issues, completely satisfied, and have only used laundromat twice in order to get it all done at once. We usually run loads about every three days if we have hookups.
In our previous Montana we had the combined Splendide washer/dryer and it took f o r e v e r to do one load. Would not work for us full timing.
Last edited by Iceman1777; Nov 8, 2017 at 07:59 PM. Reason: Add comment about combined unit
Old Nov 9, 2017 | 06:09 PM
bigredtruckmi
Veteran: Navy
Here is the picture of the washer area in our fifth wheel
Old Nov 9, 2017 | 10:11 PM
mrgrayaz's Avatar
mrgrayaz
Splendide it is then! Or do like we do and just use the park laundry. Our 5th literally doesn't have a spot for one
Old Nov 10, 2017 | 06:18 AM
djousma's Avatar
djousma
Agree with you Dave, and now see what you are talking about. So yea, a vented Splendide is probably your best choice! The trick, if your manufacturer didnt indicate where the vent should be drilled, is to find the spot with nothing behind it. You might call/email to see if they can tell you where the vent should be cut.
Old Nov 10, 2017 | 09:43 AM
whooboy's Avatar
whooboy
Lowe's has this LG 2.3-cubic foot High-Efficiency Stackable Front-Load Washer. Has anyone tried this one?
https://www.lowes.com/pd/LG-2-3-cu-ft-High-Efficiency-Stackable-Front-Load-Washer-White-ENERGY-STAR/1000129723?cm_mmc=SCE_BINGPLA_ONLY-_-Appliances-_-ApplianceFloorDisplays-_-1000129723:LG&CAWELAID=&kpid=1000129723&CAGPSPN=pl a{ifdyn:dyn}&k_clickID=3901f25d-8e11-4a0c-80e2-9673833b0c3a
FordmanNJ
All Things Towing
Mar 5, 2016 07:27 AM
Irelands child
All Things Towing
28
Sep 23, 2015 06:48 PM
rtcalabrojr
Dec 27, 2011 01:53 PM
bobj49f2
36
Nov 5, 2011 10:02 AM
Walt750
Aftermarket Products
50
Mar 28, 2004 09:46 AM
