DPF% tells you when the DPF is full and maybe in regen, it was a freebie and he was already in there, I have an Edge monitor so it doesn't matter. No I did not have it recalibrated, they are only 3/4" taller, shouldn't be far enough off to matter. Did you get your wheels put on yet?
I did put my 20" wheels on and I did get the TPMS error message and blank readings like you did. I like the softer ride and better gas mileage!
do you have any idea if now that you have the second set of sensors learned to the truck, the truck will recognize the first set still?
thanks
I don’t know but I think it will only keep one set of sensors at a time in the computer. He had to wipe my old ones off to relearn the new ones. I dont think its possible to have multiple sets of wheels/tires and get away with it if thats what you are asking.
ya, that's what I was asking. I have 2 sets, one for winter wheels and the other in summer wheels
I haven't had my old ones deleted and my new ones programmed yet. If I get within 50 feet of my old ones the truck reads them.
Autolite, I have had some customers build a PVC capsule with a air nipple and install the 4 sensors in the capsule, Air it up and set in their toolbox, works like a charm. I also thought most vehicles had the ability to set the tpms for winter tires and summer tires. In my climate no winter tires although I run across the switches inside a vehicle or see it n my scanner occasionally.
Three bad sensors on a new set of Platinum take-offs!
Now my remote start doesn't work. The dealer couldn't fix it Saturday.
I'm taking it back tomorrow to the remote tech.
Another way to program the TPMS is to turn the ignition on (do not start), push the hazard switch on/off 3 times. you will hear a honk then instructions on the screen of the instrument panel. This worked in my 17 platinum.
