Turbo???
Old Oct 30, 2017 | 09:26 PM
Blackjack8's Avatar
Blackjack8
Turbo???
So I have a 2007 6.0 with 170k miles. I started hearing a very high a pitched whine... Initially I could barely hear "something", but now it is prettty loud right after you begin to accelerate. Once it gets going I can no longer hear it.
It is a really high pitched ear piercing whine... best way I can describe it.
Is it the turbo?
Can i drive it?
Thoughts, any help is much appreciated.
Old Oct 30, 2017 | 09:30 PM
FiznUKa's Avatar
FiznUKa
Most likely an exhaust leak possibly the uppipe bellows or if you have the plastic CAC tube on the driverside the bellows at the bottom may be cracked.
Old Oct 30, 2017 | 10:38 PM
Blackjack8's Avatar
Blackjack8
Thanks for the feedback. It sure does not sound like an exhaust leak I've every heard but then again what do I know...
Old Oct 30, 2017 | 10:44 PM
FiznUKa's Avatar
FiznUKa
If it’s a high pitch whistle then check your Driverside CAC tube. They split over time in the folds of the bellows. Also look for soot stains on the firewall on either side of the engine for the top side and crawl underneath with a good flashlight and maybe a spot mirror.
Old Nov 1, 2017 | 08:49 PM
Blackjack8's Avatar
Blackjack8
much appreciate the info....!
Old Nov 1, 2017 | 08:57 PM
J ballan's Avatar
J ballan
When my up pipe bellows cracked it would make a whine or squeal like a kettle boiling. Sure it's not the fan belt? They can get pretty loud but usually when your working it hard and the fan kicks in.
Old Nov 2, 2017 | 02:01 PM
catapeed's Avatar
catapeed
Your up pipe bellows are failing and leaking, Its not a hard job to replace just start spraying all your bolts now with PB blaster this way when your ready in a couple day to change it they will come apart easier.
Old Nov 2, 2017 | 08:31 PM
J ballan's Avatar
J ballan
Well I wouldn't call it easy. Depends on how familiar you are with with pulling your turbo. I can have mine off in about 25 mins now. lol. But it's doable.
Old Nov 8, 2017 | 03:42 PM
Blackjack8's Avatar
Blackjack8
thanks for the help... that's exactly what the problem was...
dannyg1992
Oct 4, 2014 03:51 PM
ghanson
Oct 31, 2011 03:11 AM
F 250 6 liter
May 29, 2010 07:14 PM
Bud in Texas
Sep 10, 2009 05:56 AM
keithometune
Jun 29, 2007 03:22 PM
