Camping questions.
Old Oct 31, 2017 | 11:19 AM
HRTKD's Avatar
HRTKD
Originally Posted by brandon_oma#692
My tanks are exposed underneath the camper. They have electric heaters but I have not used them. The front compartment where the waterpump is ducted with heat though. I would like to take the camper out one more time if we get a nice weekend.
If it is cold cold and it will be freezing or below most of the time I doubt we will be going anywhere. It is ok for the older kids but too cold for the little guys. 5 months and 17 months no fun if someone has to be inside with them the whole time. If I do camp that cold it will be winterized.
Most of the time we need the heat is when it gets down to the 40's or 50's at night. The kids sleep in the main area of the camper and it cools off much more than our bedroom up top. plan on heating just the main area of the camper with the space heater and letting the heat drift up to us.
My tanks are also exposed. I ran the tank heaters for a couple hours with the generator running but my grey water tank was still frozen at the valve. Once I got back down to a lower elevation and higher temperatures it thawed out OK and the dump process was normal.
Old Oct 31, 2017 | 11:46 AM
Iaff113's Avatar
Iaff113
Originally Posted by HRTKD
I was at boondocked at elk camp for almost 10 days this month. I have dual 6v Trojan flooded cell batteries (T-125). They ran my furnace just fine throughout the night and it got down to 8 degrees one night. (my furnace flaked out but that's a different issue) I have a single solar panel on top of the trailer and it came real close to recharging my batteries from the furnace draw. It was nice and sunny most days. The only reasons I ran the generator was to run the microwave or to make sure the batteries were topped off on days that weren't quite as sunny.
I tried using my Big Buddy heater on the lowest setting and I couldn't handle the odor. The kerosene type smell was just too much. I had to get up in the middle of the night, open some windows to clear the air and then turn on the furnace. Due to recovering from throat cancer I'm probably a bit more sensitive than others when it comes to smells. If it hadn't been for the smell it would have worked just fine.
So when you do this. Does this replace the battery that came with the camper? Just parallel them together and is the original battery cables?
Old Oct 31, 2017 | 01:07 PM
HRTKD's Avatar
HRTKD
Mostly. You'll need a new battery box to hold both batteries. If you have a tray I suppose you could just place the batteries on the tray but you'll need a way to secure them.
My trailer came used with two batteries already. So I don't know if the OEM wires were used or not.
The wiring is different depending on if you use dual 6v or dual 12v batteries. Be sure you understand exactly how to wire it up. Either way, one or more additional wires are needed. My dual 6v setup requires only a single wire connecting the two batteries.
Old Oct 31, 2017 | 01:20 PM
scraprat's Avatar
scraprat
Top Answer: 5
Here is a quick read to get you started. http://deepcyclebatterystore.com/con...s-dry-camping/
Old Oct 31, 2017 | 01:27 PM
scraprat's Avatar
scraprat
Top Answer: 5
Using the big buddy we always have 2 windows cracked to allow a small amount of fresh air in or you will get that strong smell this also allows some of the extra condensation to escape.
Old Oct 31, 2017 | 01:47 PM
Iaff113's Avatar
Iaff113
Thanks. This is what I will switch too.
Old Oct 31, 2017 | 01:51 PM
HRTKD's Avatar
HRTKD
I knew the propane heater generated moisture but I wasn't aware of how much. After starting my heater I watched the humidity reading inside the trailer creep up, up, up! I think it went up at least 25 percentage points.
Old Oct 31, 2017 | 02:18 PM
scraprat's Avatar
scraprat
Top Answer: 5
Breathing through a sponge isn't fun.
Old Oct 31, 2017 | 04:39 PM
seventyseven250's Avatar
seventyseven250
Just to echo what the folks above said that you should be able to run the furnace fan enough overnight without a generator. If you can't, something else is wrong.
If you are worried, ways to help is to make sure the whole trailer is 100% up to temp before your genny is shut off, and also get your hot water tank full of hot water too. That thing radiates most of it's heat back into the trailer in my experience.
Old Dec 16, 2017 | 03:58 PM
TrippinStfflr's Avatar
TrippinStfflr
Yeah, upgrade your battery bank. Maybe even add solar. Get a space heater but be careful. They're one of the leading causes of fires. And like someone else said, talk with the management and your neighbors. If your neighbors dont care, the management wont. Usually if you're in a place that doesnt offer power than someone else is already using a genny anyway. I've heard many furnaces that were loader than a honda, lol.
northwindone
Oct 30, 2014 02:57 PM
Mike-11
Feb 8, 2014 11:57 PM
muddyford911
1997 - 2003 F150
Oct 25, 2011 05:15 PM
FordTruckNoob
21
Feb 11, 2008 12:52 PM
dcexplorer
Oct 1, 2002 08:31 PM
