Camping questions.
Old Oct 30, 2017 | 06:51 PM
Iaff113's Avatar
Iaff113
Camping questions.
Ok so at the race this weekend. The camp ground rules are quiet time at 11pm. This would mean generators off. I have two 2000 inverters so they keep the noise down and when in the bed of my truck you can’t hear them at night. What do you guys do if you have to shut the generators down at night. Temps where in the 30s so I don’t want the family freezing, and my battery will not last that long. I could only imagine if it was 90 out.
Old Oct 30, 2017 | 07:07 PM
IMASAP's Avatar
IMASAP
The very first thing I did when I bought our camper was install a second battery. You will want a matched set,... brand, size, age.
Old Oct 30, 2017 | 07:15 PM
brandon_oma#692's Avatar
brandon_oma#692
What are the generators running? Electric heaters or just the furnace fan?
Places I go to with quiet hours means no loud generators. Quiet generators are OK with us but check to be sure.
Old Oct 30, 2017 | 07:16 PM
brandon_oma#692
Big buddy heater should be on your Christmas list
Old Oct 30, 2017 | 07:18 PM
Iaff113's Avatar
Iaff113
Well last weekend they were running the furnace and just keeping the water pump on. I ran my inverters all night because they are quiet but I was just thinking if I had to completely shut down, what would I have done.
Old Oct 30, 2017 | 07:19 PM
Iaff113's Avatar
Iaff113
Yeah I have a few of these for the duck blinds.
Old Oct 31, 2017 | 04:19 AM
jhedges's Avatar
jhedges
Campers use propane for heat. There should be no need for a generator throughout the night. Now if you were running the air conditioner throughout the night then you would probably need the generator.
Old Oct 31, 2017 | 06:55 AM
Iaff113's Avatar
Iaff113
Yeah but you need power for the blower to push heat. That’s what I am trying to figure out. My one battery will not run that long. Maybe I’ll give the paired batteries a try.
Old Oct 31, 2017 | 07:07 AM
JayTheCPA's Avatar
JayTheCPA
^ X-2. Consider checking with the campground management / Host first as that is who is likely going to come knocking at O-dark hundred if a neighbor complains. Agree that the inverters will probably not bother anybody, but . . .
^ X-2. Or get a unit without an integrated fan for 100% heat, 0% power draw. Unless I am missing something, only down-side is no thermostat.
^ X-2. Consider AGM's. While they cost a bit more, internal loss and overall performance is better than a flooded cell.
For comparison, went completely dry a weekend in a 32' TT where the first night was ~18* F and the second ~23*F. Furnace ran near continuously from sunset to dawn both nights. Probably went through 30 pounds of propane. Managed to go the whole weekend on parallel 12v batteries with a small boost from two 5W solar panels and about 45 minutes of back-feed charge from the truck (Note: disconnect solar panels when charging from the truck). Remain convinced that the only thing that allowed the batteries to last that long was the catalytic heater, otherwise I am sure the furnace would have exhausted the batteries early in night 2.
Old Oct 31, 2017 | 08:25 AM
brandon_oma#692
Fyi I do not plan on using my furnace at all once I have the big buddy installed to the trailer lp.
Old Oct 31, 2017 | 09:33 AM
JayTheCPA's Avatar
JayTheCPA
That will work as long as the holding tanks are empty and / or temperatures remain above freezing. Have seen where manufacturers route a heating hose through the holding tank area to prevent freezing down below.
Old Oct 31, 2017 | 09:36 AM
MisterCMK's Avatar
MisterCMK
Sounds like your battery is junk. A standard deep cycle will run the furnace at night when it's cold.
Old Oct 31, 2017 | 09:46 AM
HRTKD's Avatar
HRTKD
I was at boondocked at elk camp for almost 10 days this month. I have dual 6v Trojan flooded cell batteries (T-125). They ran my furnace just fine throughout the night and it got down to 8 degrees one night. (my furnace flaked out but that's a different issue) I have a single solar panel on top of the trailer and it came real close to recharging my batteries from the furnace draw. It was nice and sunny most days. The only reasons I ran the generator was to run the microwave or to make sure the batteries were topped off on days that weren't quite as sunny.
I tried using my Big Buddy heater on the lowest setting and I couldn't handle the odor. The kerosene type smell was just too much. I had to get up in the middle of the night, open some windows to clear the air and then turn on the furnace. Due to recovering from throat cancer I'm probably a bit more sensitive than others when it comes to smells. If it hadn't been for the smell it would have worked just fine.
Old Oct 31, 2017 | 10:16 AM
brandon_oma#692
My tanks are exposed underneath the camper. They have electric heaters but I have not used them. The front compartment where the waterpump is ducted with heat though. I would like to take the camper out one more time if we get a nice weekend.
If it is cold cold and it will be freezing or below most of the time I doubt we will be going anywhere. It is ok for the older kids but too cold for the little guys. 5 months and 17 months no fun if someone has to be inside with them the whole time. If I do camp that cold it will be winterized.
Most of the time we need the heat is when it gets down to the 40's or 50's at night. The kids sleep in the main area of the camper and it cools off much more than our bedroom up top. plan on heating just the main area of the camper with the space heater and letting the heat drift up to us.
Iaff113's Avatar
Iaff113
Yeah I think I am going to try this type set up.
