engine light
Old Oct 30, 2017 | 07:19 AM
motokid18's Avatar
motokid18
engine light
2013 F250 Superduty 4x4 6.7l Diesel came up with a code of P20BA
Old Oct 30, 2017 | 07:43 AM
Pocketlint's Avatar
Pocketlint
"P20BA" is a redundant heater code. Its a code for the heater in the def tank. The tank heater is part of the Sender and Heater assembly.
Depending on your mileage it may be under warranty, notice I said may. Your in for a trip to the dealer and they will have to tell you what is going on. I suspect they will tell you the heater and sender will need to be replaced, if so lets hope it is covered under warranty.
I believe there are a few folks that have been out of warranty and bought the parts and swapped out the old to the new.
Old Oct 30, 2017 | 07:51 AM
Jeffh40's Avatar
Jeffh40
I've got the same code. It has been on all year since DEF fluid starts to crystallize at 12 deg F, I haven't worried about it until recently. Now it is a repair I'm thinking about since it is getting cold. Been quoted as a $700 repair from a local shop. At 140K miles, I'm not under warranty. Hopefully you have lower mileage.
Old Oct 30, 2017 | 08:29 AM
motokid18's Avatar
motokid18
thanks for the info guys, i am at 335,000 so probably no warranty.
I am however not shy to repair my own vehicles so i will tackle it myself. I imagine there are aftermarket o
Old Oct 31, 2017 | 02:04 AM
Pocketlint's Avatar
Pocketlint
There are others who have done it and have said it is not that hard of a job to do, and if your wrench handy I doubt your going to have a heard time taking the old out and putting the new in.
Dont forget to let us know how you make out with the repair. Good luck!
Royson12
6.7L Power Stroke Diesel
26
May 2, 2024 07:38 AM
Slowlearner
152
Mar 10, 2023 06:26 PM
grayson20
Jul 6, 2019 01:55 PM
mooreswm
Sep 29, 2018 03:53 PM
J ballan
Nov 16, 2017 12:46 PM
