P20B9 Code?
Old Jan 1, 2019 | 02:44 PM
Royson12's Avatar
Royson12
P20B9 Code?
I have 2 codes popping up. One is a P20B9 "Reductant heater A circuit open". and the other is a historical. P20BA "Reductant heater A control performance" I have no idea what either mean. From what I have found, it's possibly a loos wire on the DPF heater? could that be the issue? If so, where? LOL.... If not, what should I check? I clear the code, it seems to stay off, until I kill the truck and restart it. Its a 2013 F250 6.7 just hit 6 figures on the mileage. It is not deleted, it's bone stock, and as far as I know it has allways been that way. But, I am the second owner. I have the means to test, and repair. Just don't, know what, or where to start? Any help to save me lots of dollars would be appreciated.
Old Jan 1, 2019 | 05:32 PM
Just Strokin's Avatar
Just Strokin
You might still be within the warranty to get the DEF heater replaced. Ford recently extended the warranty. Contact your local dealer and see if your truck is eligible.
You can go to the Ford Owner site and register your truck. It should tell you if you are eligible or not. But option is to call the dealer.
Official Ford, Lincoln & Mercury Owner Site Personalized Owner Information
Old Jan 2, 2019 | 05:47 AM
Royson12's Avatar
Royson12
Thanks! I will go to the website first, I don't really trust my local Ford dealer. Lol, that's sad. From my experience with them, they seem to care more about sales, than
service. Will it tell me on the website, if it's still covered?
Old Jan 2, 2019 | 09:51 AM
Ed in Maine's Avatar
Ed in Maine
A thread of mine has some info, here.
I'd recommend dropping your DPF tank and ohming out some of the heater elements before you buy anything. I bought a new tank heater and it turns out my heated line was the issue.
Old Jan 3, 2019 | 02:57 PM
Royson12's Avatar
Royson12
I don't see it? Am I looking in the right place? I did register it, and this is what popped up. Nothing seems to do with the DEF heater?
Old Jan 3, 2019 | 02:59 PM
Royson12's Avatar
Royson12
And are these 2 items something I should have looked at? The media system did quit working for about a month, then all of a sudden, it started working again? LOL..
Old Jan 3, 2019 | 03:28 PM
Just Strokin
Apparently your truck falls into the void where the DEF sensor/heater was not covered under the extended warranty. Recently, there was another forum member who is in the same boat as you are. Not sure why Ford did not cover all the 2011-2016 trucks.
Old Jan 9, 2019 | 07:41 PM
Miler's Avatar
Miler
Good evening, all. I, too, have gotten the "P20BA – Reductant heater control A – circuit performance problem code," and I took my '14 F350 to the dealer for service. Of course, they found the same code. They ordered the heater (which is now on back order). Because I need the truck daily I could not let it sit. What I need to know is how careful do I need to be driving the truck without the DEF tank heater. We are not real cold and not below freezing often. Ideas?
Old Jan 10, 2019 | 07:56 AM
L3dford's Avatar
L3dford
I started getting this code back in Oct. on my 2013. I have Torquepro so I just kept clearing the code when the CEL came on. I've never had an issue with going into limp mode or any other issues but I did notice when the CEL is on the power is reduced some. Others have reported the same but there are those that have felt no difference in power.
I did just replace my DEF heater on the 5th, so I drove it a few months with this issue. Mine also lands outside of the CSP as well. It just doesn't make sense why 18M01 skips the 13-15 F250's and F350's.
I purchased the Dorman (904372) heater and takes about an hour to do. It's a straight forward replacement and the hardest part of this was disconnecting the electrical connector above the tank before you can drop it.
Others can chime in but all in all you should be fine driving it while you wait for the parts. If you want to do it yourself and save some $$$ there's some good youtube videos on dropping the tank and replacing the heater. If you're going to wait and it will be a while, I'd think about getting a code reader to reset the CEL if you don't have one.
Old Jan 10, 2019 | 04:09 PM
Miler's Avatar
Miler
DEF Heater
Thanks, L3 for the input. So far I have not noticed any problems, but I thought it to my advantage to hear what the boards have to say on the matter. I am also thinking of getting the Dorman unit, and I have a friend who is good (younger) at getting under the truck when I need. I did purchase a code reader just for my own peace of mind.
Thanks, again for the input.
Ray
Old Jan 28, 2019 | 04:57 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Mine is doing this. From my searching it appears they clear the code amd wait fornit to come back. Called the dealership they need to the truck 3 days minimum since they are behind. Glad i bought a vehicle i didnt need to drive
Old Aug 12, 2019 | 09:23 AM
Ginther's Avatar
Ginther
Add me to the list of victims..... 2015 with 41000 miles.
My check engine light came on Saturday with code P20B9 ... Problem with the reductant heater.
Truck also feels like it's running on reduced power, like about 60%.
Yay, now I get to take it to the dealer which is always pleasant.
Old Aug 12, 2019 | 11:34 AM
Overkill2's Avatar
Overkill2
The first item is the module behind the 8" touch screen of your truck. The second is for the EGT sensors in your exhaust. You have 4 in the exhaust system. I'm imagining that the warranty just extends the warranty coverage for either the APIM module behind the screen and for the EGT sensors if something happens.
Old Aug 19, 2019 | 06:27 PM
Lubbockguy1979
If you have the ability. Record and clear the code to restore the power. I did that for a week or so to make sure it was a actual issue. You outside the bumper to bumper warranty so likely it will cost you money unless its under emissions warranty. Im at 31k on my 16. They replaced the heater on mine
Old Aug 19, 2019 | 07:58 PM
Ginther's Avatar
Ginther
I have used Torque Pro app to clear the code. It gets rid of the check engine light, but the code comes right back. No cel but the code is still if you check for codes again without stopping and restarting the engine... and power stays reduced slightly... Not like the 50mph limit, but not normal power either. As soon as you turn the truck off and start it back up... the cel comes back.
Apparently the truck knows the circuit is broken on the DEF heater in real time. Not just at startup.
