And then start working it out. And try to get all the high areas down. Then use body filler or bondo block sand to match the surface sure fix it up.
Orich
Where that dent is on the front fender it is open on the back side, the easiest way would be to hammer and dolly. If it was in a spot where you didn't have excess to the back of the panel pullers as HIO says would be the way to go.
just watched a couple of how to videos on the stud welder but i do have access to the back(i still will be purchasing a stud welder), i've got dolly and body hammers(never used, just learning), that's going to work, thanks for the info
That bondo needs a good cross hatched base sanded surface so you can father it out into the paint. Then spray with filler primer and re-sand with wet 400. Repeat as needed till your happy with it.
