Upfitter switches amp rating
I have a 2011 F450 pickup that came with the upfitter switches. I found the wires for the switches and they all look to be 16 gage. Looking at the on line literature, it says that switches 1 and 2 are 25 amp, 3 is 10 amp, 4 is 15 amp. It shows that they all go through a relay. Are they really only using 16 gage wire for a 25 amp curcuit?
If your truck came with the Upfitter switches installed, you will have 4 blunt cut wires taped to the main harness going through the firewall. If you or someone else installed the Upfitter switches as an add-on, there should be 4 blunt cut wires in the area near the relay box. Here is the infor on installing the kit.
https://www.fleet.ford.com/truckbbas...tml/Q157R3.pdf
There is a photo in the bulletin that shows the blunt cut wires.
https://www.fleet.ford.com/truckbbas...tml/Q180R3.pdf
I dif some mote reserch. The 4 blunt wires from the outfitter switches are under the dash, left of the steering column. They are 16 gage wires and are proteted by fuses. Switch 1 and 2 ARE protected by an 25 amp fuse. 3 is 10 amp fuse, 4 is 15 amp fuse. So rated loads are about 20 amp 1 and 2, 7 amp for 3 and 10amp for 4.
they all controlld by a relay.
It looks like the E series wites fo end up under the hood, the F series are under the dash and are NOT connected to the pass through wires.
there are a few charts from the SAE and 16 gage wire can be used on 25 amp circuits if the wire is less that 3 feet.
Connecting fuel transfer pump
Can I connect a fuel transfer pump to the aux 1. The pump draws 18 amp and GPI requires a 20 amp circuit breaker. So from what I understand from the forum I should be able to use it right. The power cord coming from the pump is 12 gage. So will the 16 gage wire hold up to the 12 gage wire.
chris112lee
01-19-2002 12:02 AM
