Finally got my 6.7! Now what? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 09-22-2018, 09:59 AM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is online now
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
I ended up buying a 2014 XLT CCLB 6.7 out of Florida(I live in ct) truck has 175k miles but I only paid 20k for it.
Super clean chassis which I wouldnít of found here in CT
absoutley love the truck so far compared to my 6.0 which was the same as this truck just 11 years older and rusty.
Now, as far as EGR/DPF deletes go how crucial are they on these trucks? I know the 6.0 didnít have a dpf system but the EGR systems were prone to failure. Should I plan on deleting this truck tomorrow? Or should i drive it the way it is for a while and go from there? this truck is 100% stock.
Any info would be great. Thanks
Old 09-22-2018, 11:05 AM
kper05's Avatar
kper05
kper05 is online now
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
I'd leave it as is for now. As far as "now what," drive it! Learn what's going on with it first. If you don't know the history, it may be worth visiting a Ford dealer to pull an OASIS report. At 175k, maybe the EGR was already replaced and this one is good to go for example. Or this truck hasn't had any repairs and the truck was worked hard keeping things clean throughout the system. Sharp looking truck and it already has a good front bumper.
Old 09-22-2018, 09:16 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
fordboy2 is gaining momentum as a positive member of FTE.fordboy2 is gaining momentum as a positive member of FTE.
Very nice looking rig, wish I’d been able to find a long bed. I’m on the fence whether I should delete mine or not too.
Old 09-23-2018, 07:09 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Chuck-B is gaining momentum as a positive member of FTE.Chuck-B is gaining momentum as a positive member of FTE.
Pretty truck. I believe CT emissions tests diesel's (I see the sign in the picture), I'm in CT and my 2013 was emissions tested, if you deleted wouldn't that cause you to fail emissions?
Old 09-23-2018, 07:50 AM
SkiSmuggs
SkiSmuggs is offline
SkiSmuggs has a good reputation on FTE.SkiSmuggs has a good reputation on FTE.
Look into Enerburn or BetterDiesel FBC to help prevent DPF issues. And learn about draining the water separator on a bi-monthly basis.
Old 09-23-2018, 04:14 PM
2006powerstroke90
I will look into that.
GVWR is 11,500 on the truck. CT doesnít do emissions over 10,001GVWR so emissions wouldnít be an issue.
I work at a shop that does CT emissions and I wish we could test diesels since itís super hard to find a place that does test them
Old 09-23-2018, 04:23 PM
kper05's Avatar
kper05
Interesting. So a 2011 F250 6.7L would need emissions testing but a 2015 F150 3.5L EB is exempt?
Edit: Second guessed my memory and hand to look it up. The 11.5k on the newer F150's must be the allowed GCVWR vs just the GVWR is less than 10k. My F250 would still need emissions testing though by 1 lb.
Old 09-23-2018, 05:09 PM
2006powerstroke90
Yeah, itís strange how it works, I believe I will be doing the EGR block plates instead of removing the entire EGR cooler, and just a delete pipe, Iíve been hearing a lot of dealers wonít take deleted trucks in on trade anymore, and i want the ease of returning it to stock if I have to.
Old 09-24-2018, 10:13 AM
troverman's Avatar
troverman
troverman is offline
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
Nice looking truck. Unlike to problem-prone 6.0 EGR coolers, the 6.7L ones have two advantages: they don't fail that often, and they are very easy to get at. If you remove (or block) the EGR, you will need a tuner to tell the truck "no EGR" or you will be getting engine codes. Unless you are doing a full delete, I'd leave it alone.
Old 09-24-2018, 10:16 AM
schlepprock250's Avatar
schlepprock250
schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Or do a dpf d-lete pipe. Leave everything under the hood like it is. Just use a tuner to turn the egr system off. That way if you ever need to go back stock all you have to do is the dpf.
Old 09-24-2018, 10:28 AM
2006powerstroke90
I already have an SCT x4 for the delete, I was thinking just about doing the DPF delete and just turning the EGR off, but couldn't that still cause performance issues if the EGR cooler gets clogged with soot?
Old 09-24-2018, 10:33 AM
schlepprock250
From what I understand (still stock but researching for the near future) when a tuner turns off the egr system it keeps the egr valve closed so no exhaust gasses can enter the engine so no soot build up. I was told this by a reputable name on this and other sites.
Old 09-24-2018, 11:37 AM
Deuce40s
Deuce40s is offline
Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.Deuce40s has a very good reputation on FTE.
You need to use EGR block off plates if you don't remove it.
Old 09-24-2018, 11:43 AM
schlepprock250
I was told you don't have to use block off plates if the tuner turns off the egr system. He told me as long as the egr valve is closed nothing else is needed. Again this was told to me by a reputable name in the diesel world. If someone who knows for sure please chime in with confirmation either way.
Old 09-24-2018, 12:56 PM
Deuce40s
Deuce40s is offline
Look at the engine. The exhaust gasses (soot) travel through the cross over pipe directly into the EGR cooler. Since the computer turns off the system, there is nowhere for that soot to go. It builds up in the EGR cooler. I suppose you don't have to block off the cross over pipes if you don't mind your EGR filling up with soot. But why leave the EGR intact just to ruin it?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
