Sponsored by: Real Truck
Intermittent Cruise Control
Old Oct 28, 2017 | 02:36 AM
tperk100's Avatar
tperk100
Once I get it set, the CC works OK. But when trying to re-set speed by pressing increase or decrease controls, the CC will simply shut down. This happens most of the time. To set the speed I usually have to speed up to just about the exact speed I want, and then press the 2 controls to activate CC. Resume seems to work OK.
Something is not quite right. Any ideas?
Thanks
Old Nov 1, 2017 | 02:11 PM
jimjokjv's Avatar
jimjokjv
I just solved a very similar problem with my 2000 F250. My CC would set and then abruptly kick off. Sometimes it would work for a few minutes other times only a few seconds, then not at all.
I replaced the Brake Pedal Position switch and that did nothing to help. Then I replaced the Brake Pressure Switch at the master cylinder and now everything works as it should. Takes about 10 minutes to do.
Here is the kit I used: https://rover.ebay.com/rover/0/e1140...&sojTags=bu=bu
Old Nov 1, 2017 | 05:36 PM
tperk100's Avatar
tperk100
Jim,
Thanks for your response. The link to the kit does not work. I get a message that says....... "You can't view these order details. To view this information, you must be logged into the guest or eBay account used to purchase this item. See instructions to view guest order details."
Can you try again? Thanks, Tom
Old Nov 1, 2017 | 05:46 PM
jimjokjv's Avatar
jimjokjv
Sorry, that was the one I bought and it only lets me view the order details.
Here's the same one under at different seller: https://www.ebay.com/itm/OEM-Genuine...NZAkcW&vxp=mtr
Old Nov 1, 2017 | 06:32 PM
tperk100's Avatar
tperk100
Jim,
Thanks. I just ordered it. Someone else said that they thought it could be the problem too. What the heck? For $19 I will give it a shot. My truck is good for at least another 200K miles!! It will outlive me. (Had the head gasket / stud repair, oil cooler and egr delete, etc)
Old Dec 2, 2018 | 09:42 AM
tperk100's Avatar
tperk100
Brake cylinder switch was not help. Cleaning the CC switch contacts fixed the problem,
Here is what solved my problem
CASE CLOSED!
explorer302
Nov 12, 2018 11:08 AM
katjac
2004 - 2008 F150
Dec 12, 2010 02:03 PM
CalebC
Aug 5, 2010 12:29 PM
kevinwilly
13
Sep 7, 2009 11:52 PM
gr8tdragon
Oct 13, 2008 04:55 PM
