replace def heater and still throwing the same code
Old Oct 25, 2017 | 04:50 PM
bbq guy's Avatar
bbq guy
2011 F350 4 wheel drive 6.7.
Replace the def heater a month back and then a couple of weeks ago it throwing the same code. this is my 2nd heater I replaced.
Old Oct 25, 2017 | 04:53 PM
bbq guy's Avatar
bbq guy
was wondering if it could be the fuse?
Old Oct 25, 2017 | 05:21 PM
Just Strokin's Avatar
Just Strokin
what is(are) the code(s)?
Have you checked for any chaffed wires that might be shorting out?
Old Oct 25, 2017 | 06:28 PM
bbq guy's Avatar
bbq guy
codes are P20BD and P20BE
Old Oct 25, 2017 | 06:29 PM
bbq guy's Avatar
bbq guy
the fuse and relay are good
Old Oct 25, 2017 | 06:41 PM
Just Strokin
P20BD – Reductant Heater "B" Control Circuit / Open
P20BD triggers the P20BE
Maybe this will help
Old Oct 25, 2017 | 07:18 PM
bbq guy's Avatar
bbq guy
Just Strokin can you walk me though the diagram. New to this
Old Oct 25, 2017 | 07:39 PM
willydmax's Avatar
willydmax
Did you replace it with a Ford Motorcraft part?
Old Oct 25, 2017 | 07:45 PM
Just Strokin
I would check the Yellow and Grey wire going to the Reductant Pressure Line Heater and the Black and White wire going to ground to make sure they are not broken.
The Reductant Pressure Line Heater maybe bad. Use an ohm meter and see if it has resistance or open.
If that is not a problem, check the Blue and Orange Wire.
Old Oct 25, 2017 | 08:02 PM
bbq guy's Avatar
bbq guy
Willydmax,
no did not replace with Motorcraft part. My dealer said it would take around 6 weeks to get. So went with aftermarket part.
Old Oct 25, 2017 | 08:03 PM
bbq guy's Avatar
bbq guy
Just Strokin will look at the morning.
Old Oct 25, 2017 | 08:19 PM
willydmax's Avatar
willydmax
If the replacement part is a Dorman brand then all bets off. I'm not a fan of Dorman parts. They are very cheap Chinese parts. Did you try Autonation Ford in White Bear Lake? Their prices are awesome and they usually can have almost any part in a matter of days. Good luck and keep us posted on what you find
Old Oct 25, 2017 | 09:23 PM
Just Strokin
Looking at the code above that are stored and the wiring diagram I posted, I doubt the Dorman unit is the problem nor was the one he took out.
The code indicates the "B" heater circuit. In the diagram that would be the RDHTRC2. "B" equating to 2. Appears a problem with the Pressure Line Heater circuit or heater.
Old Oct 26, 2017 | 08:02 AM
willydmax's Avatar
willydmax
I did a little research on Identifix and you are on the right track JustStrokin. I think too that the part replaced earlier was likely ok. Those codes do not point toward the tank heater but toward the line heater or wiring issues.
Old Oct 26, 2017 | 08:57 AM
bbq guy's Avatar
bbq guy
Is there a way to test the pressure line heater? does the wiring harass on top of the def tank include pressure line heater? If not where is it located at.
