Cab Corner Replacement
Old Oct 24, 2017 | 11:28 AM
CJ06SLT's Avatar
CJ06SLT
So I've got a replace one of my cab corners, inside and out. Two main questions at this point:
1) Can I weld in the new pieces with the fuel tank installed and full of fuel or will I blow up my garage?
2) After I get this thing welded and smoothed out, how can I seal it up for a while? I don't have real painting capability, so I just want to rattle can it up for now. The whole truck needs lots of body work, so how can I best seal up for the next year until everything else it complete? What are some good products / processes?
Thanks!
Old Oct 24, 2017 | 01:09 PM
1972RedNeck's Avatar
1972RedNeck
1) I would rather the tank be full as liquid doesn't burn. Personally I wouldn't worry about it, just be careful, but I have started more than few fires in the shop in my time.
Whatever you do, have a couple fire extinguishers within reach.
Old Oct 24, 2017 | 03:32 PM
svolpone's Avatar
svolpone
i'm no expert, but i'd take the tank out. it's not that hard to do. why even chance it?
Old Oct 24, 2017 | 04:35 PM
skidoorulz's Avatar
skidoorulz
Don't make headlines. Take the tank out.
Old Oct 24, 2017 | 06:57 PM
CJ06SLT's Avatar
CJ06SLT
Yeah, it's probably better to get famous while alive. At least I'd sure enjoy it more.
Any hints on the priming / painting?
Old Oct 24, 2017 | 08:42 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
When I had the shoulder harness plates welded into my 51 F4 cab, I thoroughly soaked some old towels and wrapped the tank and filler pipe. The truck is still in one piece... no explosions, no fires.
But you should do what you think is safe.
Old Oct 25, 2017 | 03:41 AM
Crop Duster's Avatar
Crop Duster
You need to remove the tank. For one reason. You will have to get to the back side of the weld to dolly out the lumps and bumps after you weld it in and you need to get some sort of primer on the inside after its welded.
A/Ox4
15
Mar 28, 2017 08:20 AM
74crew12v
Mar 23, 2017 07:40 AM
BigBrent
Apr 29, 2014 01:45 PM
A/Ox4
Sep 24, 2013 12:40 PM
norvillebob
Oct 3, 2009 08:41 PM
