1983 Aod
Old Sep 10, 2003 | 02:21 PM
Tacit_k's Avatar
Tacit_k
1983 Aod
My 83 F-150 does and does not have a fourth gear.
It shifts into fourth yet any type of load and it lets go of the gear. is there any kind of band adjustment or is this a rebuild situation?
she grabs the other gears just fine and there was no metal or other debris in the pan when I changed the filter (save for the expected light sludge found in the bottom of the pan but nothing to indicate a major malfunction.
It seems this transmission is not regarded fondly by anyone I have talked to and the general remark I get is that spelled backwards it is D.O.A. and that is for a reason. If this is so any suggestions on swapping it out for a different unit would be great.
Old Sep 11, 2003 | 06:02 AM
rappel2's Avatar
rappel2
1983 Aod
Try adding a little bit of slack to your Throttle valve cable. This is located on the throttle along with your throttle cable and cruise control if so equipped.
Old Sep 11, 2003 | 12:51 PM
Tacit_k's Avatar
Tacit_k
1983 Aod
Actually this uses the solid TV like early T-birds and I have adjusted it with no improvement.
After Adjusting the TV I had better 3-2 down shifts on hills but still no fourth.
Old Sep 13, 2003 | 07:21 AM
71swissaqua's Avatar
71swissaqua
1983 Aod
Take a look around this site
http://forums.tccoa.com/forumdisplay.php?s=&forumid=13
These guys do alot of mods to the AOD. several on there are way smart. They've helped me alot.
The TV cable/Rod adjustment is very important for the life of the tranny. All it takes is about a block of driving with it way off to toast a tranny.
Clint
Old Sep 14, 2003 | 12:31 PM
Tacit_k's Avatar
Tacit_k
1983 Aod
great forum, I registered but have yet to get e-mail for confirmation. I can log in but without confirmation I can not post seems like there are a lot of well versed people as far as the D.O.A. transmission is concerned.
In the mean time I have moved on the the AC (dealer installed) wow I am ready to push this truck off a cliff. I can't say enough about dealer only parts.
I think I am going to pick up a junk yard AOD and toss it in and get a rebuild kit for my current AOD unfortunately at 100 miles a day on the freeway I really need that fourth gear sooner rather than later.
dougjohnson72
Jan 17, 2014 09:58 PM
Dave_north14
Aug 21, 2013 02:30 AM
xxtavixx
Jun 22, 2007 10:52 AM
jlh192006
Feb 16, 2007 12:34 PM
kray
Jan 25, 2005 09:13 AM
