1985 Ford transmission problem
Old Feb 16, 2007 | 01:00 AM
jlh192006's Avatar
jlh192006
I have a 1985 f-150 and I have a hard time shifting into second gear. I have a four speed tranny and when I push the clutch in it does not want to shift in to second when starting out or any other time but when I am moving it shifts into third and fourth gear. Then I will sit there and push my clutch in and when I go to release it it comes half way out and it sticks. Is it the clutch plate or is it the gears in the transmission.
Old Feb 16, 2007 | 04:11 AM
mtflat's Avatar
mtflat
My first guess would be the throwout bearing since it seems to stick halfway. Not engaging 2nd could be shifter fork problem or clutch plate wear, but most often its the TO bearing. Does your truck have the internal or external slave cylinder? Whats the fluid level like in your clutch master cylinder?
Old Feb 16, 2007 | 12:34 PM
jlh192006's Avatar
jlh192006
The fluid in the slave cylinder got really low. I dont know how long it will take to get the air out of the system.
1985E150pdx
Aug 28, 2014 02:52 PM
1985E150pdx
Aug 28, 2014 12:56 PM
dlsmithsr
Dec 2, 2009 05:19 PM
tyrus3k
Feb 26, 2009 06:58 AM
1985f350
Feb 22, 2007 05:33 AM
