O2 Sensor
Old Oct 22, 2017 | 07:48 PM
BWD444's Avatar
BWD444
O2 Sensor
I swapped a 1995 4.9l into a 1997 F350 that had a 5.8l and an E4OD tranny. I have it running and removed the air injection and cats as I do not need them in my state. I left the EGR and O2 sensor. I had to swap the underhood wire harness to get the engine to run as pinouts were different. I now have two O2 sensor plugs. One on the tranny that was original to the truck and a new one on the new underhood harness that runs down from the right fender near the starter solenoid. I plugged into the latter as that is what the 4.9l used is this right or should I use the one on the tranny? I only have one O2 sensor.
Thanks, Brian
Old Oct 23, 2017 | 05:57 AM
Franklin2's Avatar
Franklin2
The wiring harness you used was a 1995 with a 4.9? If so, does a 1995 4.9 use two O2 sensors? Some of the engines did.
Old Oct 23, 2017 | 08:07 AM
BWD444's Avatar
BWD444
O2 Sensor
Dave,
Both the original harness and the '95 4.9l only had one O2 sensor. But now I have the two plugs because of the underhood wire harness swap. Just wanted to make sure I am using the right plug so the computer sees it correctly. I assume using the one from the 4.9l is correct as I had to swap in a '95 PCM also.
Thanks, Brian
kabcpapc
Aug 2, 2019 01:19 PM
Edward W Rudhman
Jun 10, 2018 09:46 AM
JoePeeper
Jul 7, 2013 07:40 AM
teamlx88
Sep 28, 2012 06:40 AM
wrenchman2
Exhaust Systems
17
Nov 18, 2011 05:03 PM
