Weird brake problem
Old Oct 21, 2017 | 06:31 PM
Justynantone's Avatar
Justynantone
Weird brake problem
Hey guys
I have a 95 f150 5.8 auto 4x4 and having a brake issue. When i hit the brakes there nothing it the top of the pedal and when i get closer to the bottom the brakes start to work but if i go too far then i lose almost all braking power. Ive replaced the front rotors, calipers, pads and master cylinder trying to figure out the problem. I talked to my dad which knows his way around a ford and he thinks it might be the proportioning valve. What do you guys think?
Old Oct 21, 2017 | 06:51 PM
Cummings Guy's Avatar
Cummings Guy
What have you done with the rear (disk/drum?)? ABS?
Old Oct 21, 2017 | 07:09 PM
Justynantone
I havent done anything in the rear as it all looked good but its drum and im not sure it it has abs
Old Oct 21, 2017 | 07:30 PM
Justynantone
Just looked under the hood and didnt see a abs module so i believe that it doesnt have abs
Old Oct 21, 2017 | 08:37 PM
Cummings Guy
The rear self adjusters are known to not work right. Either because of mechanical problems or people don't drive the way necessary for the adjusters to work.
Did your problem happen quickly or over time?
Have you inspected the rears and adjusted the shoes?
The rear brakes have to have some pressure built up before the fronts will get pressure. If they are out of adjustment it will require more pedal travel to build pressure. Sounds like they are way out of adjustment.
Old Oct 21, 2017 | 08:57 PM
Justynantone
I got the truck on trade and it had the problem i will take a look at the rear brakes agian tomorrow and see if i can adjust them properly
Old Oct 21, 2017 | 09:26 PM
Cummings Guy
Take the time to pull the drums and give a good visual.
When I put new shoes on my truck I didn't even use the star wheel for adjustment. I would slide the drum on feeling for drag then adjust repeatedly until the drag felt right. Then I would tighten two lug nuts on the drum and verify the feel of the drag. (On my truck the nuts would not go on far enough to touch the drum so I used 1/2" CPVC couplers for a spacer.) This saves a lot of frustration and FN around with the star wheel. When the drum is off make sure you learn which direction is tighten on the star wheel and write it on the backing plate with a paint pen. This will help if you need to adjust later.
My truck has a locking differential so I had to pull the axle shafts so the drum would spin freely.
Let me know what you find out.
Old Oct 21, 2017 | 10:07 PM
mrollings53's Avatar
mrollings53
Yes, your truck has rear wheel ABS. Haven't you noticed the amber ABS light in the instrument cluster when starting the truck?
JAYW
1997 - 2003 F150
Jan 27, 2024 08:11 PM
DaRooster911
Oct 17, 2011 03:40 PM
Greg250
Jun 8, 2005 09:09 AM
WaterdogF150
Nov 22, 2004 07:42 PM
auzzie_ranger
1983 - 2012 Ranger & B-Series
Jul 19, 2002 02:28 PM
