ABS problems
Old Jul 17, 2002 | 07:26 AM
auzzie_ranger's Avatar
auzzie_ranger
ABS problems
I just did a brake job on a 96 xlt extended cab 4X4 Ranger both rear drums and shoes and front rotors and pads. They were well past worn. Problem is now the ABS goes off for no apparent reason. Pulling out of or into a parking space at VERY SLOW speeds only on a tight left turn. The ABS will activate without even touching the brake pedal. Tried unplugging the whole system, both the fuse and the battery to reset the "brain box" and neither works. The ABS works normally under emergency conditions (I have tried it!) but this problem is driving me crazy. Any help would be appreciated.
Old Jul 17, 2002 | 10:31 AM
Ken00's Avatar
Ken00
ABS problems
Do you have RABS or 4wABS? Did you adjust the rear brakes properly?
Old Jul 19, 2002 | 10:57 AM
auzzie_ranger
ABS problems
>properly?
It is 4w ABS and the rear brakes were adjusted (tightened) as per the Haynes manual. I think I may try to bleed the system and see if that helps. As I used c-clamps to compress the calipers. Hopefully no non-repairable damage was done during the process. If there are any other suggestions I am all ears. Thanks again!
Old Jul 19, 2002 | 02:24 PM
Ken00's Avatar
Ken00
ABS problems
If you don't figure it out you will need an OBD-II scanner to pull the ABS code.
Old Jul 19, 2002 | 02:28 PM
Ken00's Avatar
Ken00
ABS problems
zora
Sep 15, 2012 10:02 AM
zrt600guy
Feb 14, 2012 04:10 PM
bcschreib
Aug 19, 2006 03:56 PM
whackerboy52
Jul 4, 2006 03:37 PM
