Coolent leak
Old Oct 20, 2017 | 06:43 PM
bc75's Avatar
bc75
Coolent leak
I have a coolant leak under the intake coming from the water pump.Its the metal line. My problem is it doesn't go to the firewall it makes a u shape comes back then it breaks off to 2 then the heater hoses connect. The car only has 52,000 miles on it doesn't look like anyone has ever worked on it. I cant find the hoes i need.I almost forgot i have a 1999 Navigator with the 5.4 32v DOHC Intec engine.
Old Oct 21, 2017 | 07:20 AM
bc75's Avatar
bc75
Found the part finally. Its part number XL1Z-18663-DA. Does anyone no how it comes off the water pump?
Old Oct 21, 2017 | 09:39 AM
alloro's Avatar
alloro
Hmm, it's been a while but I believe once you remove the bolt holding the metal tube the tube pulls out of the pump housing. If there is a rubber O-ring on the tube it should be replaced.
Old Oct 21, 2017 | 10:37 AM
bc75's Avatar
bc75
When i replace o rings can i get them anywhere or is it ford only item.
Old Oct 22, 2017 | 08:51 AM
alloro's Avatar
alloro
Anywhere, as long as you can match the size.
guitar_199
1997 - 2003 F150
Jan 13, 2024 02:56 PM
bwf4054
Mar 4, 2019 08:58 AM
COVeteran
Nov 23, 2017 06:47 PM
25Horseplay
37
Oct 7, 2013 03:48 AM
flatline911
Sep 4, 2005 06:13 PM
