Coolant leak HELP!!
Old Oct 8, 2012 | 08:22 AM
25Horseplay's Avatar
25Horseplay
Coolant leak HELP!!
My father's 2001 7.3 is leaking coolant out of a metal tube located on the front passenger side of the block next to the water pump. I cannot see where this tube goes on the to of the motor due to the A/C bracket. What is this tube and why is it leaking? Any help would be appreciated. (it pours antifreeze when running) Thanks
Old Oct 8, 2012 | 09:11 AM
clem1226's Avatar
clem1226
Sounds a lot like a heater hose...it is probibly leaking because it has a hole in it.
Old Oct 8, 2012 | 09:19 AM
25Horseplay
It is not a heater hose, this is a open metal tube that could be a breather or drain for something.
Old Oct 8, 2012 | 09:27 AM
Kdr358's Avatar
Kdr358
Looking at my 7.3 I don't see any metal lines on the block near the water pump. If you could take a pic we could lead you to a fix. Right now it's just a shot in the dark.
Old Oct 8, 2012 | 09:40 AM
25Horseplay
I'll have to get a pic, its only visible from underneath the truck.
Old Oct 8, 2012 | 10:09 AM
DieselOrings's Avatar
DieselOrings
SPONSOR
It sounds to me like you are describing the water-in-fuel drain tube that comes down the front of the engine on the passenger's side and stops about half way down. It is a small 3/8" metal tube.
Are you sure it is not fuel rather than coolant?
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old Oct 8, 2012 | 10:23 AM
25Horseplay
^^Yes that sounds about right, and its definitively coolant coming out. Any idea why?
Old Oct 8, 2012 | 10:35 AM
DieselOrings
SPONSOR
The drain tube comes directly from the fuel bowl drain valve. No way would coolant come from that tube.
__________________
Old Oct 8, 2012 | 10:40 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
What color is the fluid? Like Bob said, if you have coolent coming out of that line, you have big problems.
Old Oct 8, 2012 | 10:49 AM
Brother Les's Avatar
Brother Les
Sounds like green diesel.
Old Oct 8, 2012 | 11:05 AM
25Horseplay
Like I said it is coolant. empty's out the coolant tank. I will get a pic this afternoon.
Old Oct 8, 2012 | 11:53 AM
Stewart_H's Avatar
Stewart_H
You got my curiosity piqued.
Stewart
Old Oct 8, 2012 | 03:11 PM
Pitcrw6's Avatar
Pitcrw6
Subscribed......
Old Oct 8, 2012 | 04:25 PM
25Horseplay
This is the tube that is leaking coolant when running.
Old Oct 8, 2012 | 04:39 PM
Pitcrw6's Avatar
Pitcrw6
Yep thats your fuel bowl drain tube. If its for sure coolant then you have a big problem. I'm not sure how your fuel bowl is filling up with coolant. Sounds impossible to me. Light the liquid on fire and see if it burns.
