dirty air filter
Old Sep 10, 2003 | 12:31 PM
F0rdF0rever's Avatar
F0rdF0rever
dirty air filter
I was detailing my engine this afternoon and made my way to the air filter. The thing was very dirty. So I sprayed it down with the hose... Would be alright to put back in a little wet so I can drive to the part store and get a new one??
Old Sep 10, 2003 | 02:19 PM
susana's Avatar
susana
dirty air filter
I would strongly sugest that you not only,thow out that filter and replace it with a k&n.And if you have not yet replaced your airbox with an aftermarketyet i would do that asap.while your under the hood check your airbox for a dirt reidue.You may have the beginning of a dusted engine! Good luck susana
Old Sep 10, 2003 | 02:21 PM
Bob Ayers's Avatar
Bob Ayers
dirty air filter
No flame intended, but if he puts in a K&N, he will for sure to have
a dusted engine, due to the dirt a K&N filter will pass!!!
Stay with the OEM filter to keep your engine clean!!!!!
Old Sep 10, 2003 | 02:22 PM
johnsdiesel's Avatar
johnsdiesel
dirty air filter
I agree that the filter MUST be replaced, but I would not use the K&N or some of that dust will get into the engine. I posted this numerous times before, but K&N filters are not a good match with a turbo diesel. Cummins, one of the most respected names in diesel engines, says specifically NOT to use a K&N filter because it can cause damage to the engine.
Old Sep 10, 2003 | 02:30 PM
susana's Avatar
susana
dirty air filter
Sorry i guess I should not so hastily have answered as to replace with a k&n filter,I dont have anything bad to say about the OEM filter.Its not the problem behind these dusted engines.My oppinion is you should be the most concerned about your airbox,and check it frequently for dirt passing the filter.
Old Sep 10, 2003 | 07:23 PM
F0rdF0rever
dirty air filter
There was some dirt in the airbox but nothing after the filter... And how do I know if the box has been replaced?
6686L
Jun 23, 2008 11:24 AM
bodabdan
36
Jun 8, 2005 10:50 PM
LCinNC
Sep 27, 2004 06:35 AM
cepfire
May 28, 2003 01:41 PM
indy10
Jan 31, 2002 11:11 PM
