Multi Function turn signal/high/low beam/wiper switch
Blinkers quit working, so I replaced the multi function arm. No change.Any suggestions? I did take the arm apart, found considerable corrosion, but nothing that I could see that would be causing the problem. Replaced the unit to be safe.Four ways work, bulbs all good, fuses good, wiring is good.
Reason: added more detail.
The truck sat, untouched, for 6 years in a very wet environment. With all of the corrosion I have found, I didn't want to put the old one back on. The fuses are all good. I checked those right off the bat.
Ok. Forgive me if this is a stupid question. How can I tell if this is bad? I am trying really hard to work on this truck myself, with no help....it's a bucket list thing
It needs to click while the turn signal switch is engaged. If it doesn't click replace it. You should be able to hear it, or feel the click by touching the can. I would also replace it if the turn signal indicator light doesn't flash, but remains lit while the turn signal is engaged.
