Sponsored by: Real Truck
Gem or something else
Old Oct 18, 2017 | 01:24 PM
Jep85's Avatar
Jep85
I have a 99 ford f350 with the v10 and 180000 miles. Around June it died and I replaced the tps and it worked for a couple months then the same problem came back. I have since replaced the tps, pigtail coming off the tps, checked the iac it was good. Currently at the shop but they can not duplicate the problem. Always the same problem, revs up once on its own, cel starts flashing and then it starts running rough. It will usually die within a minute or two after it revs up. The shop thinks it might be a gem module. Any other ideas?
Old Oct 18, 2017 | 10:47 PM
99f350sd's Avatar
99f350sd
I dont think the gem on a 99 controls anything to do with the engine. No Ideas...need more info.
Old Oct 19, 2017 | 06:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
What error codes are you seeing?
Old Oct 19, 2017 | 06:30 AM
projectSHO89's Avatar
projectSHO89
It ain't the GEM module. Best idea I can come up with is to find a shop that knows how the Ford system works.
FWIW, there was likely nothing wrong with the TPS, either, based on the reported symptoms.
Old Oct 19, 2017 | 07:43 AM
Jep85's Avatar
Jep85
The computer will not hold any codes. I can run a scanner on it right after it happens but no codes will be present.
Old Oct 21, 2017 | 11:44 AM
superdave02f552's Avatar
superdave02f552
my early 99 was giving me similar fits. no codes ran as described. ended up disconnecting one COP at a time noting idle quality change, ended up having two bad cops. the first was very clear that there was no change in engine performance the second one you really had to pay attention that nothing changed, put those in and it runs like a top
Old Oct 21, 2017 | 05:36 PM
projectSHO89
Have you tried pulling codes during the same key-on ignition cycle as when the MIL flashed? If you power off and the circuit that supplies KAM isn't working, the PCM will reset within a few minutes of the engine being switched off.
Old Oct 23, 2017 | 09:31 PM
Jep85's Avatar
Jep85
I have tried that. Saturday it died in my driveway so I ran the code reader on it while the key was still in the on position so it hopefully would not lose power and drop a code. I have now replaced the plugs and boots, cleaned the iac and egr, replaced the crankshaft position sensor and put a new battery in it. I will see this week if it acts up on me again.
Old Oct 24, 2017 | 06:46 AM
projectSHO89
If it just died, it likely didn't set any codes. You have to catch it when the MIL comes on while operating.
78 Ranger
Electrical Systems/Wiring
Nov 12, 2011 07:45 AM
flcbell
Jan 12, 2005 05:14 PM
LuvRPgrl
Mar 14, 2004 07:24 AM
bmjd
Sep 2, 2003 03:01 PM
AbadDriver
Bronco II
May 14, 2003 02:30 PM
