IAC module
Old Jan 7, 2005 | 04:36 PM
flcbell's Avatar
flcbell
IAC module
I have a 1997 Ford Explorer with a 5.0. I had problem with my idle during damp weather on intial startup. After troubleshooting I found the IAC module not functioning. I removed the module and cleaned the carbon out with non-corrosive contact cleaner (so it does not destroy the rubber parts). I worked the module back and forth until the plunger and spring work loose and not stuck. I reinstalled the module and it worked like a champ.
Old Jan 9, 2005 | 11:07 AM
tony b.'s Avatar
tony b.
Hello , i have 987 expl. spt. trac with this idle problem i also took the iac sensor off ,did the cleaning thing but nogo still had the problem so i replaced it $115.00 from dealer guess what still having the idle problem, any suggestions?
Old Jan 9, 2005 | 11:11 AM
marragtop's Avatar
marragtop
Have you pulled the engine codes? If so, did they reveal anything? If your problem is during damp weather as the previous post said, it could be the ignition wires.
Old Jan 9, 2005 | 12:49 PM
tony b.'s Avatar
tony b.
What excatly do you mean by pulling the engine codes, do you mean like a code reader of some sort?
Old Jan 11, 2005 | 11:37 PM
flcbell's Avatar
flcbell
Yes to pull the codes you need to hookup a code scanner.
Old Jan 12, 2005 | 05:03 PM
tony b.'s Avatar
tony b.
Where can I find a code scanner?
Old Jan 12, 2005 | 05:05 PM
CobraXP's Avatar
CobraXP
Go to Auto Zone. They will read the codes for you for free...
Old Jan 12, 2005 | 05:14 PM
tony b.'s Avatar
tony b.
cool thanks alot Ill have to check it out this weekend
Wrecking ball
Jul 24, 2021 02:08 PM
rjent
1997 - 2003 F150
24
Jul 18, 2017 06:19 AM
Obs91
Feb 8, 2016 05:08 PM
gcburkett
Nov 12, 2015 10:23 PM
Hughesjr84
Jul 29, 2015 02:28 PM
