front end noise that nobody can diagnose
I have a 96 OBS f250 7.3 with the twin I beam front end. For several months now i have had an intermediate loud clanking/clunking noise coming from somewhere in the front of the truck. It comes and goes but is very loud to the point where you can hear it over the sound off the engine and exhaust. It does it the most between 40-50mph especially if you are easing off the gas pedal. Once the noise starts, if you keep your foot on the gas the noise will continue but as soon as you let off the gas the noise will stop. It is a metallic sound like something metal is loose and is flapping around hitting something.
I have taken the truck to two different mechanics so far and neither of them have been able to diagnose what the noise is or where its coming from. Both mechanics checked everything possible (suspension wise and drivetrain wise) in the front end and could find nothing wrong. Hubs, bearings, u-joints, ball-joints, tie rod ends, etc..all checked out to be fine. First mechanic said if he had to guess, maybe the front leaf springs are loose and are slapping against each other while driving. Second mechanic said it sounds like the noise is possibly coming from the area underneath of the drivers seat and pointed towards a possible transfer-case problem.
I am ready to beat my head against the wall trying to figure out whats wrong with this thing. Any thoughts or info of what this could be would be greatly appreciated.
Thank you
Thank you
Could be a cracked flex plate.
Do you have an aftermarket down pipe? They can rub against the firewall and transmission if not enough clearance causing a heck of a metallic sound.
Tighten up your fender bolts. There is a piece of fiberglass type of material in between the fender and frame and it can flex causing a very loud clang or clunking sound. Very hard to locate, spent over $1500 in front end parts and no one could locate the noise. Mine were snug but not tight, tightened them down real good and noise was gone for good. Sounded like the front end was falling apart, even stopped a few times to check. A real head turner for sure.
Picture of those fender bolts ...
Thank you
Thank you
If so, have you tried locking the hubs and driving like that?
Thank you
Thank you
Zeropowerstroke99
10-15-2023 07:20 AM
