Factory fog light kit or LED cubes?
Guys, I'm wanting a little more light on the Ex and am trying to decide whether or not to buy a factory fog kit or custom install some LED cubes or a light bar instead? I always like to keep it "factory" clean if possible but not sure how much the factory fog lights actually do for me?
Does anyone know where a full kit can be had anymore? All the part numbers I can find are obsolete. I can piece together a light bracket and lights, as well as the harness but after that I am finding parts on my own. What else is needed besides the headlight switch assy to make it all work?
I used the Ford kit when my '05 was new. The actual fog lamps/brackets are different for an '05 so I had to use another set of lights.
All that being said, I would buy the appropriate factory lights and wire them up with a relay and switch.
I put 9005 bulbs in my foglights and they work well...a big improvement over the factory suggested bulbs....
I did a retrofit of the stock driving lights into my 2000...meh.
Removed them to install a pair of Rigid 2x2 lights I received for Christmas...placed them where the stock driving lights go, aimed them down (or you'll get flashed every 2 seconds)...AMAZING how well they light up reflectors in the distance!!!
The more white the light, the better you see reflectors but the worse you see non-reflective things...the more yellow the light the more you see objects, so keep that in mind. Something about how the eye picks up certain colors.
I wired mine into the F650 panel w/9 Carling Rockers from RiffRaff. Need to re-do my high beam cutoff when I install the new headlights that came in a few days ago.
Having done both, I can't recommend the LED 2x2s enough - but I can only speak to the quality of the Rigid brand.
It I use 9005 bulbs in factory lights is the wiring stout enough to handle the extra power of the bulbs?
It's fairly common knowledge nowadays as they have been making them for many years, and brackets can be had to replace the factory fogs that are usually found in those spots.
Stewart
installed these eBay specials. Once I get the Carling switches I ordered, I'll wire them in. I put them higher up to get a better close-in pattern by bumper. If the quality is decent, I will put another pair where the factory fogs go as well. I do like how these are not immediately apparent
edit: they have been installed a few days. Just realized there is a police look to them. Kinda explains why people have been acting weird and slow around me in traffic. especially when I'm in uniform
I think I’m going to try factory dogs with different bulbs and see how it goes.
