P0271, P0277
Old Sep 22, 2014 | 07:37 PM
rusbukt's Avatar
rusbukt
P0271, P0277
2005 with 94000 miles. Threw these two codes today P0271, P0277. How much should this cost me?
Old Sep 22, 2014 | 07:56 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Fuel injectors on cylinder 4 & 6 high(middle two on driver side). $260 each for injectors (Ford Remans) plus labor. A bit of trouble shooting is in order first however. Injectors failing like this can be verified before going in very far. Could also be FICM or injector harness.
Injector testing with a multimeter:
Testing the electrical side of the fuel injectors:
ok try this=set up the scanner to do a injector buzz test, make sure there is as littel noise as posiable around the shop so you can hear the injector solenoids click. run the buzz test and listen for the injector solenoids to click.
the test will buzz all 8 then one at a time, numbers 1-8 then it will repeat.
you should here all of them click if so the injector solenoids and wire harness from the ficm is ok. if all click except #1 disconnect the suspect fuel injector connector and test the injector pins for resistance. measure the resistance between the suspected fuel injector pins,component side.
pins 1 and 2 =0.2 to 3.0 ohms
pins 3 and 4= 0.2 to 3.0 ohms
pins 1 and 3=greater than 10,000 ohms
pins 1 and 4=greater than 10,000 ohms
pins 2 and 3=greater than 10,000 ohms
pins 2 and 4=greater than 10,000 ohms
if the resistances are not within specs the fuel injector solenoid is bad and the injector will need replaced.
if the resistances are good you need to check the ficm.
Restlesswildman
Jun 19, 2015 09:03 PM
c4jlca
Jan 13, 2013 03:32 PM
Fordenthusiasts
Apr 28, 2011 01:05 PM
Ratkat
Aug 29, 2008 05:36 AM
19704X4F250
1983 - 2012 Ranger & B-Series
Jul 5, 2008 08:53 PM
