Failed smog
Old Oct 19, 2017 | 04:04 PM
  #46
D-rat's Avatar
D-rat
Originally Posted by Fert
better idea, move to a free state with no emissions especially for older trucks..
Fert
Kinda like the free state I'm in that allows concealed carry without a permit and has 80% public land for me to recreate on year round. I have suggestions on what they can do with their smog testing though....
I am originally from Wyoming....I miss it there, but there was no money to be made there in my field.
Old Oct 19, 2017 | 07:00 PM
  #47
Fert's Avatar
Fert
several other states to choose from, unless u do the Hollywood stuff.
Fert
Old Oct 30, 2017 | 11:09 AM
  #48
D-rat's Avatar
D-rat
Well I love Arizona and I've lived here for almost 25 years. It's also where my job, my family, and my friends are. Moving simply to avoid smog is kinda silly.
I finally sought out some help. I could not find vac leaks significant enough to cause the lean misfire I was having. A trusted shop pulled the carb and it had gunk in the venturies and jets, and float levels were off. I took it back through and she passed with flying colors....barely registered any HCs by comparison.
Good to go. Off to get the trans rebuilt and hopefully I'll be back on the trails shortly.
Old Oct 30, 2017 | 07:53 PM
  #49
Fert's Avatar
Fert
sounds great, happy trails
Fert
Old Oct 30, 2017 | 07:58 PM
  #50
Jklnhyd's Avatar
Jklnhyd
Glad to hear it all worked out.
Old Oct 31, 2017 | 09:26 AM
  #51
KULTULZ's Avatar
KULTULZ
Thumbs up
Glad it was something fairly simple...
Back in the day...
A car came in for a major tune every 12 months. One step was a carb overhaul as the 2100 and 4100 were so simple.
With today's fuel (meant for closed EFI Systems - not open air carburetion) it might not be a bad idea to throw a kit at it once in a while.
Old Oct 31, 2017 | 10:02 AM
  #52
EQCMCAT's Avatar
EQCMCAT
D-rat,
The shop you took your rig into that cleaned your carb, by chance did you ask or the tech mention any benefit of using a bottle of carb or fuel injection cleaner to aid passing SMOG tests?
Old Oct 31, 2017 | 10:25 AM
  #53
Jklnhyd's Avatar
Jklnhyd
I dont see how that stuff would make any difference.
EQCMCAT, are you having issues? I am not too far away
Old Oct 31, 2017 | 10:28 AM
  #54
farmallmta's Avatar
farmallmta
Thumbs up Meangreen92 must adjust carbs in his sleep!
Originally Posted by meangreen92
How about your idle mixture settings, where are they? They should normally be about 1.5 turns out from tightened/bottom/fully seated.
If your choke is indeed not staying open after warm-up, then you might just need to adjust it by turning the bi-metal spring housing. It probably doesn't need to move much, and you might found that you went too far the next time you start it in cold weather...
^^^ You're reading some of the best idle/choke adjustment guidance ever posted on FTE. If you can use a vacuum gauge (auto parts stores will loan you one, and Harbor Freight sells usable ones cheap) you'll find just the settings he's talking about. This sounds like a pretty easy work-through for you.
Old Oct 31, 2017 | 12:05 PM
  #55
D-rat's Avatar
D-rat
Those tips are in my tuning box of tricks. I have a vac guage. I did not tear down the carb, though, and that's what needed to happen.
cpr.kll1
Sep 5, 2016 05:35 PM
andrewscofield
Apr 18, 2016 11:43 AM
montana62
13
Sep 22, 2009 11:11 PM
94montana
Feb 23, 2006 01:33 AM
littlefoot
Jan 18, 2004 12:11 PM
