OEM Ttrailor Brake Controller
Many people have purchased a new truck with a trailer tow package without a trailer brake controller installed.
Installing an OEM integrated trailer brake controller is very easy, a 30 minute job tops.
The only problem is activating the TBC. Has anyone used Forscan software and tried to do this themselves ?
The dealers in my area want between $ 100 to 130.00 to activate the TBC, to do what looks like a 5 minute job.
I did not have forscan when I installed the TBC. As you stated, installation was pretty easy. You do have to take the left-side vent housing off to access the connector behind, but it was not too bad. Probably took me 40 minutes or so start to finish.
I had the dealer do the update, and it wasn't even a 5-minute job. More like 3 minutes, with a bunch of BS-ing along the way.
Now that I have forscan, I can see that it would be simple to do it that way. Forscan is way cheaper than the dealer.
There is lots of good info on forscan here in this forum.
Good luck !
Resqguy77
2009 - 2014 F150
12-01-2015 11:08 AM
RX 1 Liter
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-22-2011 09:38 AM
