Hey Simon, check the TBL (Third Brake light) or the connection, blown / corroded .
Have you fitted LED tail lights , that seems to cancel and cause problems with the CC .
Good luck.
No brake light LED, but I've fitted LEDs in the white tub-lights.
I'll remove the fitting and clean the bulb & connectors and see how I go.
I'm loving the projectors. Just have 55w halogen bulbs in the low beams -even that is 1000% better than stock. And when the high beams come on, which are high-efficiency LED bulbs (complete with a cooling fan in the bulb base) the light output is astounding. I can barely tell when I through on the 35W HID Cibie driiving lamps.
Sadly I'm not using the truck very much having finished all the renno's & don't even have it registered ATM. So much so that I'm thinking of selling it.
Even if you have fitted LED tail /rear lights that could cause your problem.
Any time you press the brake pedal it cancels cruise. TBL is known to leak and get some corrosion in it causing a (short) and acts like the light is on (brake pedal pushed).
Glad your happy with the new Projectors , shame your thinking of selling though!
Hi,
I have a Tekonsha electronic brake controller/actuator for when towing a trailer with electric/hydraulic brakes.It has a loose internal connection that flickers the brake light off on from time to time. It causes my cruise to go off when it happens. Just thought I'd mention it in case you have a similar prob?
