2014 F-250 Overheating - Ford Truck Enthusiasts Forums
Old 11-07-2016, 10:27 PM
sirblast
sirblast is offline
sirblast is starting off with a positive reputation.
I have a F250 6.7 powerstroke. A couple of days ago, I noticed that the heater was only heating "sometimes". Today, the engine overheated. I allowed the engine to cool, and continued driving, and did not have another issue with overheating.
Any ideas on possible causes?
Old 11-07-2016, 11:14 PM
87 F-150 I6's Avatar
87 F-150 I6
87 F-150 I6 is offline
87 F-150 I6 has a good reputation on FTE.87 F-150 I6 has a good reputation on FTE.
Sounds like you're low on coolant. Have you checked the overflow bottle level?
Old 11-08-2016, 06:02 AM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
low coolant but also the clutch fan, did it kick on and sound like an airplane?
Or if the coolant is full (check when cold) and the fan did kick on, then it maybe a sensor.
You should have warranty still so you should take it in.
Old 11-08-2016, 10:26 PM
remhaust's Avatar
remhaust
remhaust is offline
remhaust is gaining momentum as a positive member of FTE.
Check all the obvious first , coolant level, belt, fan/clutch. Then possibly sticking thermostat or more really.
Old 11-08-2016, 10:27 PM
remhaust's Avatar
remhaust
remhaust is offline
Just wondering why you think he should still have warranty.
Old 11-08-2016, 10:37 PM
Tom's Avatar
Tom
Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Unless he drives 50,000 miles per year he should still have an engine warranty.
Old 11-08-2016, 11:15 PM
Dakster's Avatar
Dakster
Dakster is offline
Dakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputation
If he bought it in late 2013, it would still be high at 33.3k per year.
Old 11-17-2017, 01:42 PM
maco's Avatar
maco
maco is offline
maco is starting off with a positive reputation.
I would chk. all mentioned above first.....not knowing your full repair history, but here in Canada I got my 2011 serviced @ Canadian Tire auto service 2 summers ago & then this past summer my 2012 serviced (both 5.0 engines & higher mileages) both times the thermostat was changed as they were doing other work nearby and suggested to change as they were in there.....both trks immediately had HIGH fan on noises on days of + 70-80 degrees with higher humidities.....also both tried to overheat if you kept driving!!! upon changing back both times to a FORD thermostat the problem went away & I have not had above average high heat/fan noises since....I can only assume the replacement Thermostats were either not working @ the right temperature or when open were not letting enough coolant circulation causing this problem....CTC won't tell you who makes their parts but I suspect it's Gates /Thompson products (they did years ago just not sure @ present).......Good Luck!!
Old 11-17-2017, 11:27 PM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
Your first mistake was taking your truck to Canadian tire for a service. I would bet there was nothing wrong with the thermostat to begin with. They are the biggest scammers out there. A few years back I went to them for a out of province inspection for a used car. They had a list of $2000 worth of parts and brakes were on the list even thou I had just changed the pads 1000km ago. Took it to a second shop and they had one part listed that was borderline needing to be changed, cost me $150. My dad is also a mechanic and checked the car over in Manitoba before I brought it to Alberta, so I was pretty sure they were trying to scam me.
Old 11-18-2017, 08:22 AM
Gearitis
Gearitis is online now
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
One other thing that might have happened, is somewhere along the line, the Engine coolant was low and it was topped off by a different coolant other than was was in the radiator. It does not take much at all. It has been known when adding a different coolant will make the Engine coolant gel and do a partial clogging of heater cores and radiators.
Happened to me on my 08 6.4. I know that is a different coolant as the 6.7 but the principal may still be the same. Just a thought.
Old 11-18-2017, 09:35 AM
maco's Avatar
maco
maco is offline
Sorry guys but in defence of CTC where I go...they are pretty good to me...(both trks HIGH mileage) on the 2012 they had the housing apart & suggested they change the stat ...I agreed as was parts only....the 2011 had the rad hose blew off after being on almost a year ...(not really driven till it blew off) it was their fault has they had not installed the clamp properly...no question ...as it got somewhat hot I demanded a new stat & coolant, which they did but as I said it did not function properly.... So in my mind 2 trks almost identical spec's & 1 year apart had the same problem which was fixed by replacing with a OEM stat....In fairness they made a mistake which they covered... as this is a pretty decent shop!!
Old 11-18-2017, 06:07 PM
az4x4bronc's Avatar
az4x4bronc
az4x4bronc is offline
az4x4bronc is starting off with a positive reputation.
How do you know it was overheating? What was the oil temperature reading?
arice1905
18
10-17-2018 05:14 PM
Logan Ketchum
15
06-11-2017 12:07 AM
Jonathan Coulson
1999 to 2016 Super Duty
07-13-2016 04:32 PM
Ferms5
New Member Introductions
07-09-2016 07:13 AM
bobiker
39
06-14-2016 07:44 PM
Quick Reply: 2014 F-250 Overheating
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
