351m or 351w
Old Oct 8, 2017 | 07:47 PM
dragonscrapper's Avatar
dragonscrapper
351m or 351w
Ok so the guy I got this truck from said it had a 351 modified but when I run the VIN it just shows a 351, so by looking at the picture is there any surefire way to tell if this is a 351 modified?
Curiosity has finally gotten to me and I just want to know if anything can definitely identify a 351 modified?
Old Oct 8, 2017 | 07:57 PM
75BigBlock's Avatar
75BigBlock
Ford V8 Engine Identification - FORDification.com
Old Oct 8, 2017 | 09:29 PM
EP145's Avatar
EP145
351M, valve covers and water neck
Old Oct 9, 2017 | 09:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by dragonscrapper
Ok so the guy I got this truck from said it had a 351 Modified (351M), but when I run the VIN it just shows a 351, so by looking at the picture is there any surefire way to tell if this is a 351 modified?
4th digit of the VIN is the engine code. 1977/79 F100/350: H = 351M; S = 400.
If a 351, the VIN will only decode to a 351M .. because the 351W wasn't available in F150/350 & Bronco until 1981. Not available in any year F100.
351M/400 have 8 valve cover bolts per side. There is no timing cover per se, just a flat engine cover plate.
The fuel pump bolts to the left (drivers) side of the block, its bolt pattern is at 6 & 12 o'clock.
Old Oct 10, 2017 | 02:04 AM
willowbilly3's Avatar
willowbilly3
Hmm, funny I don't even have to think about details when I look to know the difference but another big one is where the thermostat is located. Not on the intake manifold is M engine. And slightly off topic the info to help tell a 351W from a 302 is also the thermostat. If you could reach the bottom thermostat bolt with a socket and extension, its a 351. If you could only reach it with a wrench, then 302.
Old Oct 10, 2017 | 09:16 AM
SlikWillie's Avatar
SlikWillie
Send me that AC bracket and I'll tell ya.
Old Oct 11, 2017 | 06:12 AM
willowbilly3
Sight misinformation there. Only the 351M is actually referred to as the "M". The 335 engine family also included the 400 ( a stroked 351M but technically not called an M even though many refer to it that way) and also the 351 Cleveland, or 351C. All part of the 335 series and all have the thermostat sitting down on the block.
Unless you want to call a Ranchero a pickup, no pickups were ever produced with a 351C.
Old Oct 11, 2017 | 10:21 PM
matthewq4b's Avatar
matthewq4b
Don't forget the the 302C not a North American offering but still part of the 335 Series family.
Old Oct 11, 2017 | 10:26 PM
85e150's Avatar
85e150
400 (1971) came first, 351M (1975) is a destroked 400.
Old Oct 11, 2017 | 11:03 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
351M info...
Bubba's M-Block Ford V8 Workshop
M-Block 351M/400 Parts Reference
History of the Ford 351M
Rumors & Myths
351M/400 Performance Build Up
351M guru http://www.tmeyerinc.com/
And how to wake up your 351M (dang photo bucket zapped all the pics...) http://www.fordtruckfanatics.com/for...ad.php?t=13066
hemichrysler
Jun 21, 2009 08:41 AM
js2743
Nov 5, 2007 12:05 AM
krasmussen
Apr 9, 2007 09:38 AM
ford0625
16
Mar 11, 2007 01:36 AM
Shorbino
Apr 19, 2003 06:04 PM
