Hesitation Problem
Old Oct 8, 2017 | 06:43 PM
Emerald23's Avatar
Emerald23
Hesitation Problem
I bought a new 2011 Ford 6.7 diesel and the 7 yr warranty expires in May 2018. I have 30,000 miles on it. I have had it in the Kendall Ford Dealership in Eugene, Or several times for a bad hesitationproblem, with no fix. The hesitation doesn’t problem doesn’t happen all the time.
I’ve had the problem for about 4 yrsand it seems to be getting worse. When you accelerate from a stop& let off the pedal, then accelerate again it dies for. About 2 to 3 seconds, sometimes worse than others.
Does anybody have any fixes.
Thanks for any help
Old Oct 8, 2017 | 06:57 PM
senix's Avatar
senix
Take to another dealer that has a certified diesel tech.
What codes are present?
Old Oct 8, 2017 | 07:46 PM
djousma's Avatar
djousma
When you say it dies...do you mean the engine quits? Or just a long hesitation? If the latter, I'm going to suggest that is normal. I have that with my old 2011 and my 2016. If you roll into the throttle it's fine, but to do as you suggest gives me the same results.
Old Oct 9, 2017 | 12:07 PM
golfmedik's Avatar
golfmedik
Check out my thread a while back about the 6.7L stumbling. Now Ford calls it a buck/jerk upon acceleration from a dead stop. Had it for a LONG time and my text finally found it on the Ford Tech forum. It was a Mass Air Flow Sensor! After installing, the truck's computer had to be cleared a minimum of 8 times. Not a problem since.
Old Jan 7, 2018 | 08:48 PM
ftodaro's Avatar
ftodaro
I have had this hesitation problem since i bought this truck new in 2012. It is vary intermittent, I may go weeks and its fine then one day i am pulling out in traffic and its a about a t second delay before the power hits. It seams like its more frequent before the motor has warmed up but not always.
I wonder if its throwing a code?
Old Jan 7, 2018 | 09:47 PM
golfmedik's Avatar
golfmedik
I spoke too soon. The problem is back. Now they think it is the torque converter that is not releasing which basically had no stall on it. Then when the truck moves, it releases and then locks back up as normal causing the stumbling, hesitation, bucking and jerking.
Joannr24
6.7L Power Stroke Diesel
22
Aug 1, 2015 05:01 PM
alberta-ne
230
Jun 1, 2011 08:55 PM
pktwa
General Diesel Discussion
Oct 28, 2008 02:58 AM
vze2sgxa
Jan 19, 2006 06:24 PM
BufordUtah
Aug 10, 2003 02:12 AM
