power steering
Old Sep 9, 2003 | 09:54 PM
seans64''s Avatar
seans64'
power steering
i have a 65' and my power steering is real loud and the fluid is full.well its time to replace odviously,so my question is could i swap any pumps from a newer vehicle?say 70'-80's f-100's or 150's.anything will help thanks,Sean.....
Old Sep 11, 2003 | 11:16 AM
William's Avatar
William
power steering
I would change the fluid first! All of it! Then bleed the system by raising the wheels off the ground and with engine idling slowly turn the steering wheel left to right about a half dozen times, check fluid level and repeat. This may solve the problem: if not be sure you locate the cause of the noise. I'd hate to replace a pump only to discover the gear was the culprit! Look for a loose or broken bracket or bent line. Pumps fit from several years but you may need a matching bracket. If the pump is failing, replace it with the same pump. This way everything will fit.
Sean Kelly
Feb 28, 2016 03:45 PM
jerry_s
Feb 22, 2016 02:42 PM
sean9049
17
Sep 14, 2015 08:32 PM
seans64'
Nov 27, 2003 02:14 AM
seans64'
15
Oct 16, 2003 10:46 AM
