2011 Ford F350 6.7 turbo boost increases then decreases
2011 Ford F350 6.7 diesel. Issues with toubo losing boost when driving. the boost increases then decreases all the time. It almost sounde like air leaking and some exhaust noise coming from the engine bay while its cycling. yes there is some power loss while this is going on. Any help!
under the hood inspection of all turbo fittings, boots and the intercooler tubing is needed. Rule out any leaks by checking for soot. You can run it and listen as well. but check it over first without running.
Thanks for the response. I have checked the inter-cooler tubes, and replaced one. I haven't checked the codes yet, but I'm looking into buying a reader. Would you recommend the
AutoEnginuity Total Ford Scan Tool Package Enhanced Bundle ?
