Sponsored by: Auxito
No Starting
Old Oct 6, 2017 | 08:53 PM
coloradorex's Avatar
coloradorex
Angry No Starting
I just replaced my Intake manifold on my 2001 F150 with a 5.4 Triton and while I was at it I replaced the plugs, coils and fuel injectors. The plugs are getting fire and the fuel injectors are getting fuel but I can't get it to start. Any suggestions please?
Old Oct 6, 2017 | 09:20 PM
enriched&beyound's Avatar
enriched&beyound
If you give it quick spray of starting fluid will it run for a few seconds?
Other wise double check your connections to sensors and make sure that all the vacuum lines are plugged in
Old Oct 7, 2017 | 08:43 AM
steve(ill)'s Avatar
steve(ill)
How did you verify this ? Fire and fuel are what is needed along with TIMING to get it to start.
Old Oct 7, 2017 | 04:37 PM
coloradorex
No Starting
Thank you for your reply,
I have checked all the connections at the fuel injectors and coils and all vacuum lines are attached. It tries to start but just wont. It's almost like it is flooded but I don't think so. I will go get some starting fluid and give that a try.
Old Oct 7, 2017 | 09:03 PM
coloradorex
Red face No Starting
I put all the plugs into coils and grounded them out against the engine block and they all fired. I used a circuit tester and tested all the fuel injectors and the are getting fire. All vacuum lines will only go to certain locations according to the vacuum harness. I just got home from church so I will try the starting fluid tomorrow.
phoenix2012
Jan 22, 2019 06:55 PM
stuckup
1997 - 2003 F150
Dec 30, 2016 07:51 PM
skylinetowing
Aug 2, 2011 11:41 PM
piper69
Jan 16, 2011 06:12 PM
Marshall91F250
15
Nov 27, 2010 06:29 PM
