NEED HELP ON A NO START
Old Aug 2, 2011 | 10:52 AM
skylinetowing's Avatar
skylinetowing
I HAVE A 06 F450 IT CRANKS BUT WONT START. SPRAY A LITTLE STARTING FLUID AND IT WILL RUN. I HAVE REPLACE THE FICM, ICP, STC FITTING ON HPOP REPLACE THE DUMMY ORINGS. TESTED ICP I HAVE 0.80 VOLTS. DOES ANYONE HAVE ANY IDEAS????
Old Aug 2, 2011 | 10:57 AM
Coronado's Avatar
Coronado
Did you have the injectors tested for leak-down and contribution? That's the first thing you should probably do man. Hook up with quality scan tool.
Old Aug 2, 2011 | 11:31 AM
skylinetowing
Injectors are all showing good on vcm scanner I replaced one injector already
Old Aug 2, 2011 | 07:12 PM
BLADE35's Avatar
BLADE35
how the fuel pressure fuel filters ect......
at the minimum check to see that you get fuel to the upper fuel bowel it should fill fast
Old Aug 2, 2011 | 09:34 PM
skylinetowing
There new filters
Old Aug 2, 2011 | 10:38 PM
BLADE35's Avatar
BLADE35
Originally Posted by skylinetowing
There new filters
does upper bowel fill fast???
Check this fan clutch wire harness for chaff
Old Aug 2, 2011 | 11:41 PM
jimmyv13's Avatar
jimmyv13
How fast should the upper bowl fill up? I am chasing a no start condition as well and with the filter cap and filter removed and KOEO, the bowl filled approximately 1/2 in 2 seconds. Is that in spec?
Tommee
Aug 21, 2017 04:39 PM
76cougar74100
Apr 2, 2010 10:44 PM
97powersmoke
15
Sep 18, 2008 09:21 AM
76fordman
May 31, 2004 05:14 PM
Badfunkn
4 Cylinder Engines
May 29, 2002 12:58 PM
