3 Speed Remote Shift Levers
Old Oct 6, 2017 | 05:50 PM
Splash440's Avatar
Splash440
I think I know the answer to this question but, I decided to ask anyway.
I am working on rebuilding my 3 speed and wanted to remove the shift levers. I removed the pins (brad rivets) and then noticed that the ends appear to have been welded to the shaft. For the life of me I can not understand why someone would have done this. The pins were tight and the arm had little to no play.
Any ideas??
Old Oct 6, 2017 | 07:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No good reason if the pins really were holding the levers tight. I'd guess when you get the levers off you may find the shafts are wallowed out?
Old Oct 7, 2017 | 06:41 AM
Splash440's Avatar
Splash440
You are probably right. When I got the pin out I looked in the hole and it appear solid but, there is no way to tell until the weld if ground off.
So far, this is the only really weird thing I have found. Based on the age and the life the truck lived I guess that is not bad.
Old Oct 7, 2017 | 10:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Any ideas??
Old Oct 8, 2017 | 11:00 AM
Splash440's Avatar
Splash440
At first I thought they were cap ends and once the pins were removed they would slide off. But, then I found the picture you show in the Parts CD and realized they were welded on. Like I said, not sure why they did it, but they did a great job with the weld. Will grind them off and see what I have as I need to change the seals.
kr98664
Oct 1, 2020 06:28 AM
mastertreetop
Jun 3, 2018 06:55 PM
cowboywanabe
Mar 4, 2012 08:56 PM
48fordf3
Aug 31, 2010 10:39 PM
66MercMan
Jan 30, 2006 04:12 AM
