Improving the ride
Old Oct 17, 2017 | 01:01 PM
  #31
itat's Avatar
itat
Originally Posted by swankerme
I'm not a genius when it comes to the physics of driving, but I've always been told that when your tire pressure is too low, it costs you in fuel economy. So, what is "too low" for a Super Duty whose tires are recommended to be at 80 PSI? Does running 50/50 affect fuel economy?
My F-250's door sticker recommends 65 psi in the front and rear tires. They are Load Range E tires which means the maximum pressure is 80 psi but you only need as much pressure as is necessary for the load they're carrying. Here is a pressure and loading chart from Toyo Tires that I use:
Tire Load Inflation Table.pdf
I don't know what the safe lowest pressure is. The chart goes down to 35 psi but I wouldn't go below 50 psi.
Old Oct 17, 2017 | 03:33 PM
  #32
Guess's Avatar
Guess
This really depends on how the truck is geared. Yes, less rolling resistance means fractionally better fuel economy. Airing down also changes the overall diameter of the tire, and that can affect your fuel eco.
My trucks doorplate calls for 60/65psi. it is the 9,900 gvwr. Running 10-15 less psi does not seem to effect fuel economy at all for me.
Old Oct 17, 2017 | 03:44 PM
  #33
cficare's Avatar
cficare
IMHO, the door jamb sticker PSI setting is the minimum. Maximum PSI can be found on your sidewalls.
Old Oct 17, 2017 | 03:59 PM
  #34
2009kr's Avatar
2009kr
Door jamb pressure is for max axle load. If you drove an F450 with the tires at max sidewall pressure (110 PSI), you'd be very unsafe. You'd wander all over the place, bounce like crazy, and follow every rut in the road. You'd also have very poor traction and tire life.
Old Oct 17, 2017 | 05:26 PM
  #35
cficare's Avatar
cficare
So tell me where I can find the minimum PSI setting. If folks are adjusting their TPMS levels downward via FORSCAN, are they violating minimum PSI?
Old Oct 17, 2017 | 05:32 PM
  #36
Warhound's Avatar
Warhound
Well for me i added King OEM shocks a rear swaybar and an ARE MX camper shell and run 50/50 PSI and its hands down a better ride and handling.
Old Oct 17, 2017 | 05:47 PM
  #37
2009kr's Avatar
2009kr
Look up the tire load / inflation tables for your particular tire. If you cannot find one, you are probably safe using one from a similar tire (same load rating / size).
Old Oct 17, 2017 | 06:10 PM
  #38
cficare's Avatar
cficare
From the Owner's Manual:
"The Ford recommended tire inflation pressures can be found on the Tire Label, which is located on the B-pillar or the edge of the driver's door."
"Ford strongly recommends maintaining these tire pressures at all times."
I'm not going to change any minds here. Y'all do what you want ... you'll do that anyway. But after the Firestone fiasco resulting mostly from under-inflated tires, methinks I'll obey the "strongly recommended" minimum.
Don't forget those altered TPMS values are recorded in the vehicle's black box and can be retrieved after an accident.
Old Oct 17, 2017 | 06:21 PM
  #39
cattaco's Avatar
cattaco
Originally Posted by Mgjfam
I'm really not trying to be smart but....this is a Super Duty 3/4 ton truck (not an F150 1/2 ton). The ride is only gonna get so good....if you start trying to turn it into an F150, you're going to ruin the reason you bought it (to carry heavy loads).
I've know guys who buy an F150 1/2 ton and then try to use it like an F350 by hauling loads that are WAY too heavy.
I've got a 2017 F350 with snowplow prep and the maximum load springs all around - yeah it's firm, but I wouldn't call it rough riding at all. Just my 2 cents.
I ride around on old beat up gravel roads everywhere I go. Our 2 Chevy 3500's and our Ram 3500 aren't this rough. On paved roads it's fine, but where I live it's overly stiff.
Old Oct 17, 2017 | 07:12 PM
  #40
2009kr's Avatar
2009kr
Everyone can make their own choice... From the tire manufacturer for my F450, https://blobs.continental-tires.com/...ables-data.pdf
At the door plate 90/80, my tires are rated for:
Front @ 90: 3450*2=6900#
Rear @ 80: 3000*4=12000*
I sure don't need 18,900# of capacity for my truck.
I run:
Front @ 80: 3195*2=6390#
Rear @ 70: 2720*4=10,880#
This gives a tire rating of 17,270, which is more than 4000# higher than I cross the scales when towing heavy with my family on board. The truck tracks better, rides smoother, and has better traction at these pressures. I'd likely run the rear tires lower if Continental rated them lower.
Old Oct 24, 2017 | 12:35 AM
  #41
sarends's Avatar
sarends
Just bought 2017 F250 SD KR and I love the truck so far!
However, I am coming out of a 2015 GMC 2500 Denali which has less interstate bounce.
Also, I have a 2012 F250 SD Lariat that I bought new. Suffered through quite a bit of bounciness until I bought Fox shocks just about 1 year ago.
I am going to lower my air pressure tomorrow - if that isn't enough I'll get the Fox shocks.
Old Oct 24, 2017 | 08:20 AM
  #42
stattlich1's Avatar
stattlich1
I'm running my tire pressure as per the sticker on the door jamb.....70 front, 75 rear.
My truck is a bit rough riding empty.....but, it's a truck.
Load 'er up and she runs smooth.
Old Oct 28, 2017 | 12:23 PM
  #43
BIGPAPA1970's Avatar
BIGPAPA1970
What is the minimum pressure before the “low tire” warning comes on??
Old Oct 28, 2017 | 01:46 PM
  #44
Tarster's Avatar
Tarster
That all depends on what your tpms sensors are set to, if you have a programmer or forscan you can set the sensors to what ever you want.
Old Oct 28, 2017 | 02:12 PM
  #45
BIGPAPA1970
What is factory set at for f350 CCSB?
