Keep that sway bar on. My truck had no rear sway bar on it at all and this past weekend I installed the Hellwig rear sway bar. It made a noticable difference.
Adjustable damping shocks will help a lot. I run rancho 9000xls and run them at position 2 unloaded with ride being very comfortable. I crank them up to 8 when pulling the trailer and/or loading the bed and it rides very controlled.
Have you tried towing at a lower setting? Mine tows my 15k fifth wheel set to 4 very well. (F450)
Interesting thread. I am also looking to improve the ride on my 2016 F-250 and I have about the same truck as the OP with snow plow prep and camper packages. Many recommendations here to lower tire pressure when unloaded as a daily driver. What tire pressure are you guys running front and rear? I’ve had mine at 65 psi front and rear.
I run 50/50 unloaded. Definitely improved the ride.
I'm into my first month after installing the Rancho 9000's and I'm very happy with my experience so far. I set my front at "5" and unloaded the rears at "3" and the ride is dramatically better. Hooked up the trailer and pulled 300 miles on some less that great roads and set the rears at 9 and left the fronts at 5 and might have to turn the rear down a click. I'm very happy with the way these shocks perform
I'm really not trying to be smart but....this is a Super Duty 3/4 ton truck (not an F150 1/2 ton). The ride is only gonna get so good....if you start trying to turn it into an F150, you're going to ruin the reason you bought it (to carry heavy loads).
I've know guys who buy an F150 1/2 ton and then try to use it like an F350 by hauling loads that are WAY too heavy.
I've got a 2017 F350 with snowplow prep and the maximum load springs all around - yeah it's firm, but I wouldn't call it rough riding at all. Just my 2 cents.
So no one thinks ditching the 5600lb front springs is worth it? What are the springs for a ccsb 6.2 without snow plow/camper package?
I have a loaded 6.7 with snow plow prep (wanted dual alternators), and just installed a 2.5" Carli levelling kit with fox shocks and Carli front springs.
I was not pleased with the factory ride, found it stiff and bouncy. First thing I did was drop the tire pressure to 45/50 and then moved to the levelling it.
I found the biggest difference was the tire pressure by far, it made the truck much more comfortable. Shocks made a difference as well, but the springs oddly enough made the smallest noticeable difference.
I'm not a genius when it comes to the physics of driving, but I've always been told that when your tire pressure is too low, it costs you in fuel economy. So, what is "too low" for a Super Duty whose tires are recommended to be at 80 PSI? Does running 50/50 affect fuel economy?
I'm really not trying to be smart but....this is a Super Duty 3/4 ton truck (not an F150 1/2 ton). The ride is only gonna get so good....if you start trying to turn it into an F150, you're going to ruin the reason you bought it (to carry heavy loads)....
I understand your point, but you should adjust the pressure to handle the load you carry. My F450 tires, aired down to 80/70, are rated for 17k# - hardly an F150.
My 14k GVWR can never allow me to approach the 9900# RAWR, so why run the door-plate pressure rated for that load?
