Default screen at startup
Old Oct 5, 2017 | 02:21 PM
tortue71's Avatar
tortue71
Hi ! When I start the truck , the screen behind the steering wheel (sorry forgot the name) always defaults to towing mode. Is there a way to change this ? Also , the truck always counts the mileage of the trailer even when I'm not hooked up. I don't think it's normal right ?
Old Oct 5, 2017 | 02:36 PM
A&Pmech's Avatar
A&Pmech
Basically you still have it set to being hooked up to the trailer. There was a thread recently were another member had the same issue.
Old Oct 5, 2017 | 03:13 PM
natpark's Avatar
natpark
go into "trailer set up", select "select trailer" and then select "no active trailer" this will let the screen change as well as stop putting miles on the trailer odometer of the selected trailer that you where last using.
Old Oct 5, 2017 | 03:47 PM
tortue71's Avatar
tortue71
Thanks ! Its kind of counter productive that you have to turn it off each time.. the chances are that you will forget and screw your mileage anyway....
The truck detects when a trailer is connected anyway... I was expecting that when you have trailers configured when you plug a trailer the truck would just ask Wich trailer it is in the list and activate it. Then when you disconnect it would simply deactivate it and keep your mileage up to date. Am I wrong ?
Old Oct 5, 2017 | 04:09 PM
drtrussell's Avatar
drtrussell
2nd Gear
I too have the same issue, come to find out this is a bug in the software.
Old Oct 5, 2017 | 04:24 PM
ERock62's Avatar
ERock62
They should make a Stickied post about how to turn this off
CrossCut
2009 - 2014 F150
Feb 14, 2019 07:53 PM
Ewags
Jul 22, 2018 10:59 PM
wb6anp
Jun 7, 2017 04:49 PM
Spode
May 17, 2017 11:10 PM
wb6anp
Oct 11, 2016 08:49 PM
