I have a 2002 Ford F-350 Lariat and I was wondering where I can mount my TS Chip without taking the **** off? My small allen is stripped and I’m just branching out to other ideas for mounting.
I don't know of any way to "mount" it without taking the **** off. Mine was next to the radio where the backup sensor switches would go (plenty of room behind the dash for the **** and cable). Unless you could find some kind of clip that would go around the threaded neck I can't think of any other option besides let it hang and grab it with both hands when you want to switch tunes.
Originally Posted by F0rdc0wb0y
Not sure if I understand your question. Here's how I did mine
Nice! I like the discreet location. Unfortunately I can't rep you.
They make allen head wrenches where the end is shaped in a ball to be able to use them at an angle. Between SAE and metric sizes you should be able to find one that is the right size (or a hair larger), press into the set (allen) screw at an angle and be able to back it out. That set screw is only tightened into plastic so regardless of how much it is tightened it should not take too much to back it out.
You can also get a left hand drill bit (screw extractor) and that should do the trick in a jiffy.
‘Get a small extractor remove the screw, buy new screw and reinstall...
I pulled the trigger on a 77 Camper Special with a 460. Going to do very little to the exterior but do a full mechanical rebuild. The truck runs and drives but not well. I hope I didn't pay to much. What do these things go for?
