TS Mounting...
I have a 2002 Ford F-350 Lariat and I was wondering where I can mount my TS Chip without taking the knob off? My small allen is stripped and I’m just branching out to other ideas for mounting.
Not sure if I understand your question. Here's how I did mine https://cimg4.ibsrv.net/gimg/www.for...c4667f570a.jpg
Originally Posted by VMPowerstroke
(Post 17506817)
Originally Posted by F0rdc0wb0y
(Post 17507578)
Forgive me but just guy buy/borrow a drill bit and an allen.
Mount it to the right of the wheel on the kick panel for the knees. Somewhere comfortable to reach in a pinch. I sat in the truck for a few minutes with a sharpie and stabbed it and drilled (after panel was off). Make sure you torque the PCM box 10mm in the firewall to spec. I was nervous and had the truck just go to sleep on me, (not tight enough) not cool. I have a thread on it if you research, but don't forget!!!!! Don't let that PCM wiggle at all. Wire ties are your friend. Denny:-drink |
BTW,
Hack saw and patience or a grinder will make that allen new. |
(Post 17506817)
My small allen is stripped...
You can also get a left hand drill bit (screw extractor) and that should do the trick in a jiffy. |
(Post 17506817)
Originally Posted by Colorado350
(Post 18322776)
‘Get a small extractor remove the screw, buy new screw and reinstall...
Stewart |
I pulled the trigger on a 77 Camper Special with a 460. Going to do very little to the exterior but do a full mechanical rebuild. The truck runs and drives but not well. I hope I didn't pay to much. What do these things go for?
Originally Posted by Sam's1967
(Post 18324552)
https://cimg5.ibsrv.net/gimg/www.for...bcc999fe1a.jpg https://cimg6.ibsrv.net/gimg/www.for...6ca090a776.jpg https://cimg7.ibsrv.net/gimg/www.for...58b60bd6d7.jpg https://cimg8.ibsrv.net/gimg/www.for...93979bf17c.jpg https://cimg9.ibsrv.net/gimg/www.for...e03012e5a8.jpg |
I think we have crossed wires someplace in the internet!!!!!!!!!!!!!
Originally Posted by AllaboutMPG
(Post 18324608)
Thread closed. Stewart |
