A/C Clutch Wheel Alignment Issue
Old Oct 4, 2017 | 11:01 AM
1974xlt's Avatar
1974xlt
The original factory A/C compressor on my '74 F250 with a 460 had seized up. But the replacement compressor's clutch wheel turned out to be about half an inch too forward of the rest of the pulleys. I ordered a dealer installed clutch wheel and it was half and inch too short of alignment of the pulleys. Finally I ordered a clutch wheel with an inertia ring like the original had but was back to too forward. Does anyone have a solution to this problem? I'm out of ideas.
Old Oct 4, 2017 | 12:51 PM
willowbilly3's Avatar
willowbilly3
It seems somewhere back in the cobwebs that you only press them on until the pulleys line up.
Old Oct 4, 2017 | 09:34 PM
1974xlt's Avatar
1974xlt
Thanks for your reply, but the compressor shaft is coned shaped with a wood rift key. The clutch wheel just seats on it, it doesn't press on.
Old Oct 4, 2017 | 09:52 PM
orangeford's Avatar
orangeford
Had the same problem with my 460 swap. Get a clutch for a 460 for a 75 and earlier without the inertia ring and factory ac . Seems they didn't have them on truck applications until the 77-79 maybe. There are at least 3 variations of belt sheave depth on these things on a ford alone in the 73-79 era.
Old Oct 4, 2017 | 10:09 PM
1974xlt's Avatar
1974xlt
Thanks for the reply, but I started with a replacement factory '74 non inertia wheel and that was too forward of the pulleys. Should I try older?
Old Oct 5, 2017 | 06:09 AM
Ozzie H.'s Avatar
Ozzie H.
I had a similar problem when I searched for one for my '76 F-250, 460, factory air. The one I need may be the Four Seasons 47811 (new) or 48811 (reman.) It looks like:
And has
Part Specifications
  • Belt Type:V-Belt
  • Belt Width "IN":0.500
  • Can Size:w/ Coil
  • Coil Voltage:12 Volt
  • Coil?:w/ Coil
  • Color:Gold
  • Connector Type:Butt Connector
  • Description:Clutch Assemblies - New
  • Groove:1 Groove
  • Lead Wire:Lead Wires
  • Material:Steel
  • Meets or Exceeds OEM Specs?:Yes
  • New or Remanufactured:Clutch Assemblies - New
  • Style:206, 209, 210, HG850, HG1000
  • Type:York & Tecumseh
  • Clutch Dia. "IN" Primary:6.000
  • Mount Distance "IN":2.625
Pay attention to the "mount distance". It is the offset of the pulley groove.
I never found out if it was the right clutch. I reused the old one. But it sure looks like the one that's on there.
Old Oct 6, 2017 | 11:33 AM
1974xlt's Avatar
1974xlt
Thanks Ozzie,
I came up with that same number looking up a '73 Torino with a 460. I'll give it a try. Thanks again.
Old Oct 12, 2017 | 08:55 AM
1974xlt's Avatar
1974xlt
Hey Ozzie,
The 47811 clutch wheel arrived and it aligned perfectly! Thanks for the help.
Old Oct 12, 2017 | 10:09 AM
Ozzie H.'s Avatar
Ozzie H.
Originally Posted by 1974xlt
Hey Ozzie,
Thanks for the confirmation. Now I and the other forum members also know the correct one to get!
Old Oct 12, 2017 | 10:57 AM
orangeford's Avatar
orangeford
I just confirmed that is the same clutch number I used.
stainlessstroker95
Jun 12, 2011 10:44 AM
zero 2
Nov 17, 2006 07:52 PM
kidoo
Aug 20, 2006 04:14 PM
wolftan
Jul 13, 2006 01:30 PM
tbirddmnd
Jun 16, 2004 10:02 AM
