another clutch question
Old Nov 16, 2006 | 09:39 PM
zero 2's Avatar
zero 2
The last clutch discussion got me thinking about mine. After the truck has sat overnite the clutch is really 'grabby' in the morning. As I let the clutch out the truck jerks a couple of times before full engagement, it takes a couple of stops before it smooths out and has a smooth engagement for the rest of the day. Kinda thinking the oil may be a little thin in the tranny and may need a changeout...like the clutch is drying out overnite. Haven't changed the tranny fluid in a few years.
Old Nov 17, 2006 | 01:28 PM
Lazy K's Avatar
Lazy K
Hard to say but it sounds to me like you have a small amount of oil on the clutch plate. Any drips or dampness at bottom of bellhousing? If it does`nt bother you I would forget about it untill you are replacing the clutch.
Old Nov 17, 2006 | 07:52 PM
bc6.9's Avatar
bc6.9
I have the same problem...oil on the fly wheel, gets bad when I tow my 5th wheel, and when I park on an incline. Going to put up with it until I put a 5speed!
