Distributor ID?
Old Oct 4, 2017 | 08:38 AM
Jpegg01's Avatar
Jpegg01
Distributor ID?
Can someone ID this Distributor for me?
Old Oct 4, 2017 | 09:02 AM
good to doo's Avatar
good to doo
Its a general motors.
Old Oct 4, 2017 | 09:04 AM
Jpegg01's Avatar
Jpegg01
The motor is a Ford 460 so don't think it's a general motors!
Old Oct 4, 2017 | 09:07 AM
good to doo
People put them in a lot.
Old Oct 4, 2017 | 09:09 AM
Jpegg01's Avatar
Jpegg01
So what is the manufacture of the Distributor? It doesn't look to be OEM
Old Oct 4, 2017 | 09:11 AM
good to doo
Like I said its a gm single wire, They simplify the ignition.
Old Oct 4, 2017 | 09:13 AM
Jpegg01's Avatar
Jpegg01
So your saying it's not an aftermarket distributor?
Old Oct 4, 2017 | 09:18 AM
good to doo
I,m sayin someone put it in there.
Old Oct 4, 2017 | 09:26 AM
Jpegg01's Avatar
Jpegg01
I was just wanting to know the manufacture of the distributor, in case I need parts or whatever for it?
Old Oct 4, 2017 | 10:14 AM
Dave145's Avatar
Dave145
Looks like one of those fancy overpriced MSD distributors or the like. General motors style HEI setup. Only parts I'd give it would be the dumpster, then put the ford duraspark system back in.
But to answer your question, I'd bet it's an MSD distributor.
Old Oct 4, 2017 | 10:43 AM
KULTULZ's Avatar
KULTULZ
Exclamation
Old Oct 4, 2017 | 11:13 AM
beartracks's Avatar
beartracks
Looks kinda old. Definetly not GM. No where near fitting. Maybe Davis Unified Ignition, Acel
Old Oct 5, 2017 | 05:31 AM
KULTULZ's Avatar
KULTULZ
Smile
What you have is an aftermarket HEI- GM style distributor. It is produced by a couple of manufacturers.
There is an STAMPING I.D. on the bowl. You can try to cross it by going to the manufacturer(s) websites. You may see more info by removing the cap.
The resistance you are experiencing is that it is a GM system and most here have no use for the system. Nothing personal.
Old Oct 5, 2017 | 05:56 AM
Jpegg01's Avatar
Jpegg01
I just recently purchased the truck, and have no use for a GM distributor either. Just didn't know anything on it. But looks like I need to replace the engine, so will replace distributor as well. Orielly Reman engines a good buy?
Old Oct 5, 2017 | 06:08 AM
KULTULZ's Avatar
KULTULZ
Exclamation
Originally Posted by Jpegg01
...looks like I need to replace the engine, so will replace distributor as well. Orielly Reman engines a good buy?
...whew...
With today's replacement parts quality I would hate to say. Can you go through the engine yourself or do you just want an exchange?
